Wireless issues with Thomson v8 (after firmware upgrade) Updated.
- Wireless issues with Thomson v8 (after firmware up...
Re: Wireless issues with Thomson v8 (after firmware upgrade) Updated.
21-02-2011 4:56 PM
I don't know what is wrong with the latest firmware but it made my router behave like a cheap ebay router/modem, i think that someone somewhere should look into why the signal drops and wifi speeds decrease with certain routers.
Device: laptop
Make: hp
Model: G70
Device: mobile phone
Make: samsung
Model: galaxy s i9000 (But alot of people are having problems with the wifi on this phone)
21-02-2011 8:30 PM
One thing I will say my internet download speed is great.
And my upload speed is (sorta) ok when using an ethernet connection.
Here's my router details.
Here's my weird results
ON WIFI...
ON ETHERNET...
My Macbook is running os 10.5.8
Here's my Airport Card details...
Which incidentally is all "real"... (see here http://community.plus.net/forum/index.php/topic,93668.msg785928.html#msg785928...)
I'm not sure if this helps but, kudos to plusnet for the acknowledgment of the problem.
21-02-2011 10:14 PM
22-02-2011 1:55 PM
Well I'm about to upload some pictures to flickr, and before I do this I thought I'd quickly check to see if plusnet had updated the router (or not) and indeed...
Now it's still early days but I'm fairly optimistic so a quick check and...
ON WIFI...
Wahey!
Whoops...
Forgot to say thank you, to the plusnet people.
22-02-2011 2:01 PM
That's been done for you now. Should all be working fine now.
Jojo
23-02-2011 9:39 PM
In addition, since I switched routers I'm unable to connect to iChat. I have wasted much of the last 3 evenings trying to fix the iChat connection, and now it appears that the problem lies with the router, rather than iChat.
I've been a plus.net customer for 6 years on a month-by-month contract and have never had a problem, but am now getting very frustrated and annoyed with the apparently poor quality of the Thomson router. I would have been better off sticking with the monthly contract and buying a decent router myself, rather than signing up for the yearly contract in order to get a free router.
Device: MacBook Pro
Make: Apple
OS: X 10.6.6
Issue: Slow loading of webpages, slow download speeds, iChat non-functional
25-02-2011 10:48 AM
I have sent you a private message.
Jojo
25-02-2011 8:54 PM
Make :Samsung
OS : 7
Issue : unable to detect printer
Have performed firmware upgrade to 535 v8 router and re-configured as instructed by PN in forum but after one day laptop is unable to find Kodak ESP 5250 printer. It can if I restart the router every time I want to print something.
28-02-2011 1:17 AM
Laptop
Samsung Q330
Win 7
I downloaded the firmware upgrade which hasn't helped, installed inssider and changed channel so not competing with neighbours, uninstalled Mcafee security in case that
was slowing things down - nothing helped.
Google turns instant off telling me my connection is slow and shows me a basic version of images as again it tells me my connection is too slow to support normal view.....
It seems to be worst on google - constantly freezes and says internet explorer not responding at the top. Takes about 30 seconds to find search results. I reported this to Plusnet and received a text to say my connection speeds were fine and no problems detected.
BT Speedtest says it's unable to run a test on my computer despite trying numerous times.
Ran connection speedtest.net which gives the following results:
.http://www.speedtest.net/result/1177096823.png
Speedtest shows 1.60Mb/s, 0.38Mb/s and 45ms Ping.
Do these sound normal - I'm pretty technologically clueless!
This is my first wireless router so have no comparisons but my desktop computer is on the same router via ethernet and that runs fine, very fast and no freezing...any help would be greatly
appreciated as it's sooooooooo frustrating!
28-02-2011 6:33 PM
...the Thompson router is starting to play up on wi-fi.
Apple Macbook
OS: 10.5.8
Issue : low upload speed (Only on Wi-Fi)
iPhone
iOS 3.2.something
issue: low upload speed (Only on Wi-Fi {only has WiFi})
Xbox360
OS:...erm? win2k?
slow Xbox live speed (Only on Wi-Fi)
HTC Wildfire
Android
Download is still awesome though
28-02-2011 9:59 PM
Jojo are you there?! Help!!
28-02-2011 10:50 PM
After upgrading it was 5mb down, 0.36 up. more as i was expecting.
so, it seems the upgrade worked.
Laptop:
HP dv6 pavillion
Win7 64bit Home Premium
Quad core
3Gb Ram
FoB
01-03-2011 10:43 AM
If it's happening on your wired computer also it doesn't seem to be necessarily a wireless issue. I have checked your line on both plusnet and BT sides and they're both showing a profile of 7150k the VP is green, so if you're not seeing those speeds then take a look here for some tips.
Jojo
01-03-2011 5:55 PM
04-03-2011 11:20 AM
- use a cable'
- Update Firmware
- buy another router
