Wireless connectivity on the Thomson V8
- Wireless connectivity on the Thomson V8
Re: Wireless connectivity on the Thomson V8
13-12-2010 6:18 PM
There's no way I'm prepared to use WEP, especially when the router supposedly supports the much stronger WPA2.
13-12-2010 10:36 PM
Make: HP Pavillion DV6700 series
OS Vista Home Premium
i) Limited Connectivity when Laptop is powered down or restarted.
ii) Also, restricted upload speed even when connected properly 180kbps wireless, instead of 370kbps ethernet. Download speed performs normally ~6mbps ethernet and wireless.
I have raised a ticket, but the ticket now refers to a firmware fix to be published through this forum, so Plusnet must be at a stage of recognising this problem.. If this is not the case, I need to reactivate the ticket and ask for a replacement.
I am presently using an old modem / router and haven't had a problem in over 10 days, so it seems pretty conclusive to me that there are problems with the v8 wireless functionality on PCs.
Please let me know if the problem is acknowledged or if I need to raise another ticket for modem replacement.
AndrewD
14-12-2010 9:24 AM
We are aware of an issue with apple mac devices and do have a fix for that but the reason I started this thread was to try to determine issues with other OS's. I have quite a few examples now and this will help us decide whether we think this is something the current firmware upgrade will also rectify.
Jojo
14-12-2010 10:21 AM
Thanks,
Paul
14-12-2010 12:48 PM
Jojo
15-12-2010 1:44 AM
Make Fujitsu
OS Vista
Router needs reset whenever this laptop is used. Other laptop on Win7 ok
Also NAT settings on PS3 changed to strict.
15-12-2010 9:56 AM
Try unchecking the 'Enable UPnP' option, in the 'Gaming & Application Sharing' page and clicking on 'Apply'. Then re-check the same box and click 'Apply' again. That seemed to work for me and my Xbox360.
Quote from: parman Also NAT settings on PS3 changed to strict.
Paul
15-12-2010 11:07 AM
I've just replied to a similar thread in the mac forum, http://community.plus.net/forum/index.php/topic,86222.msg765550.html#msg765550
I'm getting fairly frequent invalid passwords on a macbook pro, and we've had to bounce the router for a vista laptop.
Will the fix you mention work for this and can you schedule it?
Denny
15-12-2010 11:22 AM
Device Laptop
Make Toshiba
OS windows 7
and
Device Iphone
Make 3G
OS 4.0.1
15-12-2010 2:46 PM
Yes I'll have the remote fix scheduled for you.
Jojo
15-12-2010 2:57 PM
15-12-2010 3:31 PM
Denny
15-12-2010 10:39 PM
Quote from: youngsyp Try unchecking the 'Enable UPnP' option, in the 'Gaming & Application Sharing' page and clicking on 'Apply'. Then re-check the same box and click 'Apply' again. That seemed to work for me and my Xbox360.
Paul
Thanks Paul, i will try that when i get home.
16-12-2010 1:38 AM
win vista home premium
limited connectivity on restart requires router reboot.
on the other hand
Xperia X10 mobile
Android 2.1
no problems connecting wirelessly
16-12-2010 10:05 AM
I'm back with Plusnet after a gap of 5 years. I've just finished my training period and modem is syncing at 1mb. I am experiencing the same as the other guys where my wireless upload is half of that of the wired speed. Here is the speed test from mybroadbandspeed.co.uk;
Today 08:59 515 kbps (64.4kB/s) 71 kbps (8.88kB/s) Wireless
Today 08:56 533 kbps (66.6kB/s) 381 kbps (47.6kB/s) Wired
I have been sent the Thomson 585v8 and using both Windows 7 and XP with same results.
