Wireless connectivity on the Thomson V8
- Wireless connectivity on the Thomson V8
- « Previous
- Next »
Re: Wireless connectivity on the Thomson V8
08-01-2011 10:47 AM
Was only sent this thomson router the other day from plusnet to solve my issues, now i have another problem
Device: Laptop
Make: Acer 7720G
OS: Windows Vista
Issue: Limited Connectivity
Router: Thomson V8
Firmware version: 8.2.7.7
08-01-2011 11:21 AM
08-01-2011 11:34 AM
08-01-2011 3:48 PM
I flashed mine yesterday but the fault seemed to persist even though I power-cycled the router and restarted it from the 'gateway' page. Today I unplugged the power unit and checked the PSU could supply power OK. (Don't try that at home unless you know what you're doing - you could damage the power unit or burn your fingers or worse if you get it wrong!) Anyway, I got 21.8v into 47 ohms which is close enough to the ratings, so that's in the clear.
After plugging it all back together again it's now working at present, so time will tell whether trouble resumes when it's been running a while. I'm typing from my laptop now.
08-01-2011 4:18 PM
08-01-2011 5:39 PM
My wireless network, which was working fine before this router was installed, is as follows: plusnet broadband - router - laptops (2, wireless) / Pure Avanti Flow internet radio & streamer (wireless) / iphone (wireless) / Readynas Duo server (ethernet).
The wireless internet connection works fine. However, I couldnt get my laptop to see the NAS wirelessly over the network (it sees it over ethernet), or my internet radio to see my media server (on laptop or the NAS). The radio is connected to the router and can access internet radio stations. Similarly the NAS was getting an IP fine over ethernet. This was doing my head in for the last month - thank god i was directed to this thread!
Just installed this firmware fix - I can finally access my NAS over wireless! And my internet radio can now stream wirelessly from my laptop. For some reason the radio still cant see the NAS media server - need to look into that.
All in all, thanks for this thread and fix. Pretty disappointed that Plusnet are using this router though - if it wasnt for 5 years of impeccable service, I would probably be asking for my money back.
One final thing - after installing the firmware, my internet connection dropped. Eventually got redirected to plusnet login page, but it wouldnt accept my password. So I had to go through router configuration again. Suggest this is made clear ont he firware download instructions page.
I will let you know if I still cant access NAS media server from internet radio after some playing around. It really shouldnt be this difficult! Netgear routers next time please Plusnet!!!
08-01-2011 8:51 PM
Quote from: ross1127 Kjpetrie, I take it thats theTU_Upgrade zip file you are on about
Yes.
09-01-2011 4:58 PM
Quote Personally I'd throw the router in the bin and buy one fit for purpose.
I have a 3COM router that I've had for a few years, it has done its job but recently has stopped responding overnight and occasionally during the day meaning I had to manually restart, these disconnections ended up reducing my line speed so I decided to ask plusnet for a new router as I've been with them for nearly 8 years.
Router arrived quickly (thomson 585 v8), I immediately upgraded firmware, setup encryption, got all my devices talking to them (I work in IT and am a bit geeky so there are 12 devices that connect to the router at some point).
The first thing I noticed was poor download speeds via bittorrent, a bit of tweaking got them a bit quicker but browsing the internet from other devices was really slow, when the torrent client wasn't running they were fine.
One night I was copying files from my Mac to PS3 via http and the network ground to a halt for all other wirelessly connected devices, loading google home page took at least a minute and using any flash based browsing was impossible.
Today I bit the bullet and put the 3COM router back in its place, torrents are flying, PS3 can download files and we can still browse at the same time.
I'll probably get another 3COM or decent router to replace the failing one but will never in my life subject my poor wireless devices to the thomson 585 v 8.
09-01-2011 6:57 PM
My "Standard" config is, Sony Vaio Laptop (Windows 7 Home Premium) with a HP PhotoSmart B110 wireless printer.
However to "fault find" I've also being usiing a HP Pavilion laptop (Windows Vista Home premium)
I've had all the same issues reported here, but can add a few points of analysis......
Firstly, switching off the wirelessly connected Sony laptop does indeed cause problems - for me I was able to re-connect without problem, and surf the internet, however the fault being exhibited is that I cannot print.
Fireing up a second laptop (the HP Vista one), causes me to get the "Limited Connectivity" issue being reported widely here.
Connecting the HP laptop to the ethernet ports, gives me connectivity to the internet, but it's impossible to PING either the Sony laptop or the printer from the HP Ethernet connection, nor can I ping the HP from the Sony.
So, guess what - switch off the router, and switch it on again, and all becomes well, until you switch the laptop off again.
The only final point to add is that I've allocated fixed IP addresses to the Printer and the Sony laptop - maybe that's why the laptop re-connects to the internet when restarted after a shut down?
10-01-2011 10:47 PM
Laptop
Acer Extensa 5620Z, Broadcom BCM43xx Wireless Adaptor
Windows Vista Home Premium
Tried changing to WPA, tried g mode only, channel # etc with no joy
Will try the firmware upgrade when the binary links are fixed...
10-01-2011 11:04 PM
My details, as requested are:
Device: Nas & internet radio
Make: Readynas Duo / Pure Avanti Flow
OS: n/a
Issue: Intermittant media server connectivity over wireless
Router: Thomson V8 Firmware version: 8.2.7.8 (issue seemed worse under 8.2.7.7)
11-01-2011 8:08 AM
Quote from: duncs Im only seeing the NAS media server .... every so often, and not at all today.
Surely your NAS media server is attached directly to your router with an Ethernet cable? Are you saying this gives an intermittent connection?!?
11-01-2011 11:07 AM
I took delivery of the V8 a week or so back. Problems I have are:
Poor upload speeds over wifi. This really does cripple web browsing.
I have updated the firmware to 8.2.7.8 and manualy selected an alternate wifi channel. No improvement found.
I have raised a ticket (#38642968) - but no reply in 2 days.
The speed over wifi is http://www.mybroadbandspeed.co.uk/results/70569001.png
The speed over cable is http://www.mybroadbandspeed.co.uk/results/70568781.png
I've only just taken delivery of this to replace a v7 router that suffered continuous Kernel warm restarts when using wifi. I'm not sure what these routers get right? Price?
Ian
11-01-2011 11:12 AM
Quote from: ianccole Poor upload speeds over wifi. This really does cripple web browsing.
Really? I would have thought the upload speed would have only a slight influence.
11-01-2011 11:33 AM
This issue is now believed to be resolved.
Please ensure that you upgrade your router to the latest firmware here.
If the problem still persists then please start a new thread.
- « Previous
- Next »
