Wireless Network
- Re: Wireless Network
Wireless Network
17-05-2014 4:29 PM
A firend is trying, with my permission to connect to my wireless network. On the Your router setup details" card there is a Key: quoted. However this does not work on his ipad. Can anyone suggest as to why it doesn't please?
Message 1 of 5
(703 Views)
4 REPLIES 4
17-05-2014 4:56 PM
The key is case sensitive! Has your friend recognised that?
Geoff,
York.
York.
Message 2 of 5
(338 Views)
18-05-2014 10:41 AM
Thank you, we understand that. But it still does not allow access.
Message 3 of 5
(338 Views)
18-05-2014 12:05 PM
Just to be sure, he is picking up your network, not a similarly named one?
Geoff,
York.
York.
Message 4 of 5
(338 Views)
19-05-2014 10:17 AM
Please ensure that the key typed in is the 'Wireless Key' and not the 'Router Password.
Remember, to input CAPS on the iPad, you need to either press the 'Shift' button each time, or you can tap it 3 times and that should keep the CAPS on for you.
Message 5 of 5
(338 Views)
