Wireless LED flashing red
- Wireless LED flashing red
17-04-2010 10:12 AM
What does this mean please? Can still use my Squeezebox wirelessly, but other things aren't working so well.
Please help.
Please help.
Message 1 of 4
(1,217 Views)
3 REPLIES 3
Re: Wireless LED flashing red
17-04-2010 10:49 AM
If you post what type of wireless router / access point you are using then I am sure someone here can help
Richard
Richard
Message 2 of 4
(794 Views)
17-04-2010 11:01 AM
Thomson Router that comes with plus.net
Message 3 of 4
(794 Views)
17-04-2010 7:47 PM
Hi
According to page 11 of the TG585 the user guide here it means that no security is enabled on the WIFI
I would strongly recommend that you enable WIFI security.
As a minimum use WPA, but WPA2 is better, do not use WEP as it is trivial to hack into.
Richard
Richard
Message 4 of 4
(794 Views)
