Wireless Connection
- Re: Wireless Connection
Wireless Connection
30-09-2014 7:57 PM
I seem to have a problem with my wireless connection.
Randomly over the last 2 or 3 weeks I find I cannot connect via wireless to the router.
The hard wired connection still works but everything that would normally connect (2 laptops & smartphone) don't even see the wireless connection.
The only thing that fixes it is to reboot the router!
Strange thing is all the router LEDs are green which, on the surface, says there's nothing wrong.
Has anyone else had the problem or am I looking at a dying router?
Message 1 of 8
(1,086 Views)
7 REPLIES 7
30-09-2014 8:24 PM
If its a PN supplied router I have always found wireless a bit flaky - but mainly with a lot of devices attached. They also don't seem to cope very well in congested areas with auto channel selection. have you tried switching to manual and trying a few channels? A wifi scanner on the smartphone might help you choose the best one. Otherwise it might be on its way out. I had a couple replaced because wireless eventually became unusable.
Jon
Jon
Message 2 of 8
(685 Views)
30-09-2014 11:36 PM
search technicolor tg582n telnet commands.there are commands that can improve speed and signal strength.it worked for me
Message 3 of 8
(685 Views)
01-10-2014 2:38 AM
there are some tweaks here http://npr.me.uk/
you could always switch the wireless on and off rather than rebooting the whole router, rebooting the router too many times can lead to line management kicking in.
Message 4 of 8
(685 Views)
03-10-2014 9:02 PM
I'll try the wireless on-off next time it happens.
Message 5 of 8
(685 Views)
07-10-2014 9:18 AM
You might find this helpful if you're still having the same issue: http://www.metageek.net/products/inssider/
Message 6 of 8
(685 Views)
07-10-2014 12:46 PM
The current version of inSSIDer isn't free anymore, you could use a more advanced and free alternative instead.
Message 7 of 8
(685 Views)
07-10-2014 1:00 PM
Message 8 of 8
(685 Views)
