Wifi not very good
Smileygirl68
Interested
Wifi not very good
Hi can anyone advise please my wifi isn't very good, if i take my laptop into next room signal drops to 1 bar when watching something it then starts buffering.... I am faily new to plusnet.
Thanks to all
3 REPLIES 3
Alex
Fixes: 12
Re: Wifi not very good
Which router are you using?
A PlusNet supplied one?
Is your laptop signal good when nearer the router?
I think you can try changing the channel or splitting the 2.4 and 5 Ghz bands and see if using either separately makes a difference in your property.
Smileygirl68
Interested
Hi Alex
Thanks for your help, yes when the laptop is in the same room i have full signal.
I'll give it a try today, thank you
EmilyD
Fixes: 111
Thanks @Smileygirl68,
Please let us know if you continue to experience connection problems after you've changed the WiFi channels and split the bands.
Do you experience any problems on wired connections or is this solely a wireless issue?
 Emily D
