Wifi Speed 50% Slower than Wired
- Wifi Speed 50% Slower than Wired
05-12-2012 8:36 PM
I'm new to Plusnet, so haven't posted before - but could really do with some advice.
I've had Fibre Extra fitted today, with the Technicolour 582n router. My wired speeds are amazing - 72/16. However, any device I am connecting wirelessly is only getting speeds of 37/16. The devices are all wireless n enabled, so should be capable of getting roughly the same speed as wired.
Didn't want to put it through as a fault yet because PN will probably tell me the line needs a while to stabilise etc.
Anyone else have this problem? Seems like s duff router to me!
Message 1 of 6
(1,097 Views)
5 REPLIES 5
Re: Wifi Speed 50% Slower than Wired
05-12-2012 8:48 PM
welcome to the forums Fobocop
there have been a few complaints raised on the forum about wireless speeds with that router
Message 2 of 6
(602 Views)
05-12-2012 8:54 PM
Thanks for the welcome!
Yeah, I can only think that the router is the weak link here - I'd be interested to hear from anyone who has upgraded.
I know 37/16 is ok for most things, but it's the principle really!
Message 3 of 6
(602 Views)
06-12-2012 10:30 AM
Could anyone confirm whether they have experienced a similar drop in performance when using this router, or should I put it through as a fault?
Message 4 of 6
(602 Views)
06-12-2012 1:05 PM
It depends on what you are connecting with..
Most (if not all) phones and tablets only use a single antenna, which (IIRC) limits them to 64mbps, subject to distance.
So gettings 37/16 sounds about right, and is consistent with my my phone and tablet.
Good Laptops and Desktops with multiple antennas are required to get more than this.
Message 5 of 6
(602 Views)
06-12-2012 1:11 PM
Ah okay,
That's good to know thanks. I'm new to Fibre - having previously been getting about 12/1 through ADSL, there was very little difference between wired/wireless.
It comes to something when your broadband is too fast for your equipment!
Thanks again!
Thanks again!
Message 6 of 6
(602 Views)
