Why o Why is my broadband speed so low
- Why o Why is my broadband speed so low
Re: Why o Why is my broadband speed so low
11-08-2009 8:48 PM
11-08-2009 8:59 PM
In theory Plusnet can request it but it isn't easy or simple getting BT Openreach to change it.
If, however, you download Routerstats http://www.vwlowen.co.uk/internet/files.htm there is this option which allows you to reduce your noise margin and also get better logging of what is happening (ignore the fact that I am using an older version - I can't be bothered to upgrade it)
12-08-2009 12:07 AM
12-08-2009 8:56 AM
12-08-2009 9:06 AM
This was a clean install of version 5.6
12-08-2009 7:07 PM
12-08-2009 7:12 PM
When you do a resync what is the noise margin reported as immediately afterwards.
That is the number you put in the default noise margin box - it is probably 15dB but it is better to check first
12-08-2009 8:58 PM
that is with both with both 'target snr' boxes set to 6 and pressing Rx Sync
12-08-2009 9:09 PM
12-08-2009 9:41 PM
We are using Routerstats not DMT
@neepdocker see this picture for what you do - note there is a limit to how far you can drop the noise margin.
As a first try use these numbers
12-08-2009 11:22 PM
OK
This has given me Rx noise 12.6 and Rx sync 2720
tried copying the stats again but for sum reason refuses to copy and paste
What will I try next ?
12-08-2009 11:38 PM
12-08-2009 11:41 PM
13-08-2009 12:03 AM
Speedtester result
Test1 comprises of Best Effort Test: -provides background information.
Your DSL connection rate: 3040 kbps(DOWN-STREAM), 448 kbps(UP-STREAM)
IP profile for your line is - 1750 kbps
Actual IP throughput achieved during the test was - 1619 kbps
13-08-2009 7:15 AM
