Why does my next door neighbour get much better download speeds?
- Why does my next door neighbour get much better do...
- « Previous
- 1
- 2
- Next »
Re: Why does my next door neighbour get much better download speeds?
14-03-2012 11:14 PM
Right, just tested with the router plugged into the test socket and there is little difference in the speed, in fact it was a touch slower.
Message 16 of 21
(490 Views)
14-03-2012 11:22 PM
trouble is powering up at this time of night will give you a lower speed, you are better to wait till weekend and reconnect your router between 9 and 3, you will get a better synch speed
Message 17 of 21
(490 Views)
15-03-2012 8:34 AM
Ok, thank you for that. I will report back after the weekend. I also thought that I will probably need to provide all the report data rather than just check the download speed?
Message 18 of 21
(490 Views)
15-03-2012 2:10 PM
HI Westonian,
When you're in the test socket you should look at the sync/connection speed rather than the download speed as this will be what determines your overall speed once profiles are aligned.
Jojo
Jojo
Message 19 of 21
(490 Views)
15-03-2012 10:23 PM
Will do! Thanks Jojo.
Message 20 of 21
(490 Views)
16-03-2012 7:48 AM
Where I live, about half the houses have a 30-40 dB line to the telephone exchange and the other half have 60 dB+ to the same exchange. I'm in the lucky half but my neighbour next door but two isn't so I get about four times the download speed that he does!
Message 21 of 21
(490 Views)
- « Previous
- 1
- 2
- Next »
