Why do i get usage when i am in Spain
- Why do i get usage when i am in Spain
17-10-2008 7:49 PM
Paid-for 72.04MB 9.91MB 74.15MB 476.21KB 11.92MB 27.8MB 18.97MB
Free 534.87KB 272.47KB 64.57KB 69.82KB 60.74KB 61.22KB 62.28KB
Total 72.57MB 10.18MB 74.21MB 546.03KB 11.99MB 27.86MB 19.04MB
Its not really a problem as i wont get anywhere near my 30 gig this month but just wondered how this was possible when the computer
was switched off for most of that time ?
Re: Why do i get usage when i am in Spain
17-10-2008 7:53 PM
When you say your computer was switched off for most of the time, would you say it was possible this was turned on each day, if only for a short time for email downloads or Windows / antivirus updates?
17-10-2008 8:08 PM
17-10-2008 8:15 PM
To give you more of a definitive answer I'd like to have a look at an hourly breakdown of your usage to see if the usage each day is at a fixed time or whether it is equally spread throughout the day. I can't view such a breakdown at present though because I'm not at work. If I get chance I will have a quick look tomorrow and report back if I notice anything interesting or unusual
In the meantime, do you have any other equipment connected to your router? A NAS drive or VoIP system for example?
17-10-2008 8:49 PM
17-10-2008 11:54 PM
18-10-2008 5:52 AM
Quote from: Fantasticfourum No i havent got anything connected to my router and i dont know what WEP or WPA is so i wouldnt know if was switched
WEP & WPA are encryption protocols, and if you have a wifi router you really should check to see that thay are enabled.
Otherwise other people can login and use your connection - and more importantly could go to some nasty web sites and leave you liable if illegal activities take place over the connection.
What model of router is it.?
18-10-2008 2:28 PM
Is it possible your connection is being used during these times?
If not I would definitely recommend that you look at your wireless security setup and ensure this is enabled.
18-10-2008 2:42 PM
18-10-2008 3:05 PM
For example my router logs the date, time, protocol, source (IP address + port), and destination (IP address + port) of every access.
18-10-2008 10:56 PM
