Which BB Option
weirddave
Which BB Option
I'm currently on PlusNet Broadband Premier Option 1 and have noticed there are Broadband Your Way options, should I stick with my current option at £21.99, or move to Your Way option 3 for £19.99?
Both have a 20GB limit, but Premier 1 starts getting restricted at 13GB, then further restictions at 17GB.
Any thoughts,
Dave
4 REPLIES 4
jelv
Fixes: 10
Re: Which BB Option
What is your typical usage?
How much of your off-peak usage do you use between 8am and 4pm?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
weirddave
Re: Which BB Option
I use a download manager, currently set to download between 12am and 4pm, so the usage is quite high.
jelv
Fixes: 10
Re: Which BB Option
Peak time on BBYW is 8am to midnight, so unless you can reschedule to midnight to 8am you are probably better off sticking to Premier.
weirddave
Re: Which BB Option
I could, but that would halve my downloading time, I'll stick with Premier.
I was just about to say I couldn't find the 8am info, but just spotted it.
Thanks for th help,
Dave
