Where do I go from here?
- Where do I go from here?
- « Previous
- Next »
Re: Where do I go from here?
25-02-2010 12:11 AM
I'm away from home for about ten days next week & not using B'band. Would this be a good time to request the training period be set? Router etc left powered up 24 hrs etc.
Does one usually experience a fall back from the +ve figs I seem to be getting at present or will it start @ say 3.5megs d'load or show a gradual rise on this over the training period. Elementary Q I'm sure for some!
Many thanks, Ian
25-02-2010 1:00 AM
With being away should you ask for a training reset? My suggestion is not to, just feel being around to keep track of what is going on is best. There might be a time when restarting the router could be helpful, and you can't do that if you aren't there. What I suggest is to leave the router on (PC can be off) to run up around 14 days (hopefully) with a nice stable connection. The DLM might react to that by reducing the target noise margin itself (which will cause a re-sync). 14 days has been known to be a DLM threshold period, though it can be twice that (or more, or never).
If the target noise margin is reduced (by the DLM or by initiating training) the IP profile won't change from its present value at first (which means a speedtest done instantly gives unchanged results and users start typing their complaint on the forums). Hopefully over the training period it would settle at a higher value, giving the appearance that speeds creep up.
David
25-02-2010 7:45 AM
CSC reckoned yesterday ALL was resolved. Shots below show SNR back up, line dropping & d/load speeds conversely down. At time writing 3.7 yeterday, now 2.7mbps.
Hopefully someone from PN will read this, please.
25-02-2010 10:48 AM
I've powered down router/waited and on again. SNR dropped back from 22>15, fine but @ exchange end it seems to have stuffed the BT IP profile as well as download speeds. [below]
Will everything recover & how long, please.
25-02-2010 11:12 AM
Latest, SNR risne to 33 & d'loads 0.7 and falling.
Is it just a v. bad day? Systems, events beyond our control? BTw letting everyone down?
Or my line that has been singled out?
25-02-2010 11:16 AM
25-02-2010 11:27 AM
Will wait to see if PN pick up later in the morning, my earlier forum posts.
25-02-2010 1:10 PM
It looks to me like one of the large bursts of noise you experienced previously has returned and screwed up your connection again. I think the sync speed changes (with associated fall in IP Profile and speed-test results) are consistent with this behaviour, and the 'cure' is for Plusnet and BT to identify the source of the noise and eliminate it.
You current sync speed is back to the pre-noise value, but it will take 3 days for the resulting increase in IP Profile and speeds to show. Unfortunately on past history the noise might reappear in the meantime and continue to screw up your connection.
Not good news.
David
25-02-2010 1:26 PM
I have entered a recent blunt [still polite] message on my ticket.
Unless PN can kick BTw [if that is where the problem lies?] into respong in a more professional approach to customer's woes, then we are all in for a bleak future. Do they lack the technical skills, I don't know but if the PN staff are the jam in the middle, then it is pretty demotivating stuff.
Ian
26-02-2010 12:03 AM
Never knew it could change as dramatically as this but in the right direction. Will see what the 'morrow brings forth.
26-02-2010 12:14 AM
David
26-02-2010 9:57 AM
Yesterday, Thursday [total collapse/disaster day] when I thought everything was lost & the only honourable thing to do was admit defeat/throw in the towel; sunshine came near to midnight. Such a sudden upturn, caught me off guard to be honest.
The speeds are now back, BT speedtester 3.4/3.7Mbps, SNR back to 15, straight, steady line. Sounds like bragging but not meant to be; when I read the Forum & SHUTTER's + others situations, I'm grateful.
Added to that, this forum is an important reason in my view to hold in with PN. Excellent resource; comments, advice, encouragement etc. Indeed, you have been one of the stars. So, I would hope to close the ticket, ongoing since December. Hopefully now with a tick in the box, 'sorted'.
- « Previous
- Next »
