Where do I go from here?
- Where do I go from here?
04-02-2010 6:22 PM
"Quality Test and Eclipse test passed ok, looks like port reset has reset profile and is ok now,customer happy".
Yes, the customer was happy for 6 days on IP profiles 5000 & d'loads 4.1M - 4.4m. Excellent.
Day 7 and BT speedtest this morning IP profile 4500 & d'load 4057; this evening IP profile 500 & d'load 385
Summary, back to where I was before the BT engineer arrived. Hopeless & so disappointing.
Much as I would like to, how can I recommend a service like this to anyone?
Re: Where do I go from here?
05-02-2010 7:49 AM
Download speed - 171 Kbps
acceptable range of speeds is 50-250 Kbps.
DSL Connection Rate :3616 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 250 Kbps
In 24 hrs exactly,from 4057 d'load & 4500 IP to this.
My patience and faith in PN/BT sorting out an acceptable service is about zero.
05-02-2010 10:48 AM
I've got one of our faults guys looking at this for you now.
05-02-2010 9:14 PM
Download speed was - 167 Kbps
Acceptable range of speeds is 50-250 Kbps.
Your DSL Connection Rate :4384 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
Ian
06-02-2010 8:30 AM
Download speed was - 210 Kbps
For your connection, speeds are 50-250 Kbps.
IP profile on your line is - 250 Kbps
Since my home set up was OK'd by BT 8 days ago and running consistently at 4.4 Megs for six days, surely problem is @ PN or BT exchange?
06-02-2010 8:34 AM
06-02-2010 12:03 PM
I do not understand what this 'unknown' gateway is, all I know is that when I think my d'load figs can get no lower, they do!
06-02-2010 4:09 PM
06-02-2010 5:41 PM
Guess I'll just have to be patient until beginning of the week and let the creaks in the system work their way out. Hopefully someone @ PN will assist then refreshed after a restful w/end, I trust.
08-02-2010 1:10 PM
Download speed was - 166 Kbps
For your connection, the acceptable range is 50-500 Kbps.
Your DSL Connection Rate :4160 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 500 Kbps
With 'pipes', gateways, etc. [I don't understand the significance nor do I have to] problems, have things behind the PN scene settled down and when can I expect to bet back to 4meg d'loads and a normal service, please?
08-02-2010 1:17 PM
You need top find out why you had a series of low sync rates which caused your IP Profile to drop to 250kbps and then only recover to 500kbps
The chances are that this still says 250kbps https://portal.plus.net/my.html?action=data_transfer_speed
08-02-2010 3:19 PM
My troubles only seemed to start when since pm.last Thur. & through the w/end, severe disconnections brought everything down. PN confirmed that I was now stable! Think B'band shows down 0.2, up 0.4
Anyway, thanks for your reply.
09-02-2010 11:03 AM
Can anyone explain please a BT engineers comment 'reset port at xchange'? When he did this 10 days ago service levels were great.
09-02-2010 5:22 PM
09-02-2010 5:58 PM
Just have to wait for someone from PN to pick things up - I can't go on like this.
