When will we get Fast Response Profiles
- When will we get Fast Response Profiles
17-09-2011 9:45 AM
I read about 6 months ago that BT was to introduce a new form of fast response BRAS profile - BRAS Quantification.
So instead of waiting for days to get higher speeds after a "go-slow" incident it would happen immediately if the sync rate of your line increased.
I believe the roll-out was to be late Summer 2011.
Has any Plusnet user had experience of these new profiles yet?
Has Plusnet implemented them yet?
I believe Plusnet also apply a profile to their servers which would need to be aligned with the new BT Profiles - if or when they are implemented.
My line has an intermittent fault so that ocassionaly its resyncs to a speed of say 650kbps which then sets my IP profile to 500.
If I manually resync when the line become stable the sync speed goes to say 1200 kbps but my line is throttled to 500kbps by the BT and Plusnet's profiles.
Message 1 of 5
(806 Views)
4 REPLIES 4
Re: When will we get Fast Response Profiles
17-09-2011 10:16 AM
the trials are supposed to end in mid October and then it will be rolled out to all 21CN exchanges - but not 20CN
This gives a bit more information http://community.plus.net/forum/index.php/topic,97746.msg825915.html#msg825915
Message 2 of 5
(402 Views)
17-09-2011 10:18 AM
@Allotrope
why don't you get BT to fix your line?
To do is to be - Neitzsche
To be is to do - Kant
do be do be do - Sinatra
Message 3 of 5
(402 Views)
17-09-2011 11:39 AM
Oldjim, thanks for the reference.
I doubt that my rural exchange will be upgraded to 21CN anytime soon - so it looks like I need to chase BT again if I am to get a consistent "high speed" - if 1Mbps is considered high these days!
I have had many vists from BT to try and fix the problem. They have given me a new NTE5, replaced 300mtres of drop wire to the house and just replaced a section of overhead cable damaged by trees - after 4 months of waiting. This last repair I was assured would fix the problem. It has'nt.
Many thanks for the feedback.
Message 4 of 5
(402 Views)
19-09-2011 12:27 PM
That's BT for you and there is nothing we can do about it. The same as BT won't enabled my area FTTC and probably never will be.
Message 5 of 5
(402 Views)
