When will router be sent?
- When will router be sent?
26-04-2013 2:37 PM
I get my Fibre installed on Monday but the View order status for the router still says Hardware dispatch pending
The order has not yet been placed
Isnt this cutting it a bit close because even if its posted tomorrow, it cant get there till monday at least and the engineer is booked for 8:00 - 13:00
Not that bothered because hopefully the engineer will use the router I have which is fibre enabled anyway.
Keith
Re: When will router be sent?
26-04-2013 3:06 PM
Firstly welcome to Plusnet and our community forums.
Your router has been dispatched today and it should have been dispatched prior to this, unfortunately a system error prevented this.
You'll be able to use router either way, and if you haven't received our router you can always create a PPPoE if needed.
Let me know how you get on with your install.
Chris
26-04-2013 3:27 PM
26-04-2013 5:08 PM
@MisterW Thanks for that, No doubt ill play with the settings no matter what
29-04-2013 12:05 PM
I got fibre installed today but still not got router so engineer couldnt test connection. The dsl light on the modem is solid green so thats a good start, but cant work out how to connect router I have and the direct connection to the pc from modem isnt working.
29-04-2013 12:31 PM
Quote but cant work out how to connect router I have
What make/model router do you have?
29-04-2013 12:36 PM
29-04-2013 1:04 PM
29-04-2013 1:29 PM
29-04-2013 1:50 PM
edit: looks like Adam's replied to your other thread here http://community.plus.net/forum/index.php/topic,114482.0/topicseen.html
29-04-2013 3:04 PM
29-04-2013 3:06 PM
That looks pretty good, you must be quite close to the cabinet.
29-04-2013 3:10 PM
