What would cause TG582n to to lose WiFi on all devices at the same time
- What would cause TG582n to to lose WiFi on all dev...
Re: What would cause TG582n to to lose WiFi on all devices at the same time
16-02-2014 7:06 PM
Rather than endless speculation, you could see exactly what was going on over your wifi if you captured the wireless traffic in monitor mode using Wireshark or Microsoft Network Monitor.
16-02-2014 7:58 PM
16-02-2014 8:16 PM
No don't have Facebook or Twitter in use. Cant uninstall then, but I don't have an account with them anyway. Wouldn't touch these social networking sites with a bargepole.
Dont want to speak too soon, but on the 8.4.4.j firmware currently have no issues.
Its all very very odd.
16-02-2014 8:33 PM
16-02-2014 9:42 PM
It is odd to say the least
& since some wireshark experts are highly recommending Wireshark et al
Can they please answer some of the questions that have not been answered & some not asked as yet, before I even attempt to install the likes of wireshark et all
1. Is the Portable version ok to use or do I actually require the full instal version
2. Are you wanting me to use the most up to date version or the same version as you have installed
3. Will it need to be run using Administrator rights
4. Do I have to make any adjustments from the default settings, IE:Set the Capture filter etc
5. Is yes to number: 3 then what adjustments has to be made
6. What should I pay particular attention to IE: TCP, IP Address etc
16-02-2014 10:08 PM
16-02-2014 10:36 PM
However
Let me clarify
Wireshark is no good for this cause, after requests for me to install / run
Therefore that would of been a waste of time resources / & space on the drive ?
Microsoft Network Monitor may be good for this Cause, Yet not good at the same time ?
Therefore more confusion is afoot
Please advise the absolute correct procedure / program / settings etc for me to follow
I am willing to test etc as have already been proved
However we do not need more confusion added to the equation / unnecessary programs / unsure if your advised programs will / will not work
Until 100% sure of what program / settings etc is required for testing, then I will not be installing any until we know for sure
Edit:
I also urge PlusNet to have a word with their suppliers in case they have heard of same / similar issue(s) with the other ISP's they supply to, & possibly have a fix in place or a workaround
Surley as there are millions of TG582n's in the wild, myself & Penfold can not be the only ones to have suffered from these issue(s)
Myself = 3 x TG582n's affected on the same Hardware
2 x NON USB on 10.2.2.B EH Firmware
1 x USB on 8.4.4.J Firmware
Penfold's (Please correct any error(s))
1 x NON USB on 10.2.2.B Firmware
Downgraded to 8.4.4.J Firmware
16-02-2014 11:19 PM
What I would like to know is what percentage of routers are returned, and if known for what reason. It would be the greatest coincidence ever if its just me and you affected, and I just cannot see that
16-02-2014 11:32 PM
Unless all factors have been considered we will never know if we are the only 2
(to which I also doubt),
Out of X amount of millions / country wide & quite possible worldwide with various ISP's across that range
It would be nice of PlusNet to ask Technicolor in any case, would it not ?
We have eliminated so much, including
Devices we use as they are different
The only thing in that respect & same is the Facebook app that is disabled & not in use (which was mentioned earlier)
The TG582n Router
Therefore I find it realy hard to grasp that it is anything on our internal network that is causing this (yet to be proved otherwise though)
I think it is definitely a TG582n issue unless it is caused by that disabled (Unable to uninstall) Facebook app that still updates itself, as I have had the TG582n since December 02/12/2013 no issue(s) until 23/01/2014 which was after Facebook did a behind my back update.
17-02-2014 7:01 AM
I think the problem is due to the 582n being an overcomplicated piece of junk and it's a waste of time trying to investigate or speculate what may or may not be wrong with it.
17-02-2014 9:50 AM
I know that capturing the traffic is not 100% guaranteed, however I was referring, to the software you suggested on a system you know nothing about
Therefore are you really in a best position when
Basically you are saying
You suggest capture traffic with Software on an Operating system (you know nothing about)
You originally Stated
Quote from: ejs
<snip>
Wireshark running on Linux can capture the wireless level (802.11) packets in "monitor mode". I believe Microsoft Network Monitor can do the same on Windows (Vista or later, not XP), but haven't tried it.
Then after I ask about settings you Claim
Quote from: ejs Questions 1 and 3 imply you'll be running Wireshark on Windows, but Wireshark can't capture wireless level traffic on Windows. Instead you would need to install Microsoft Network Monitor.
Do you know for 100% certainty that Wireshark can't capture wireless level traffic on Windows machines (since you obviously do not have the experience)
The reason I ask is because you seem to have experience of Wireshark & Not Microsoft Network Monitor, to which you could advise on settings & provide better analysis
Quote Q 1.14: Does Wireshark work on Windows Vista or Windows Server 2008?
A: Yes, but if you want to capture packets as a normal user, you must make sure npf.sys is loaded. Wireshark's installer enables this by default. This is not a concern if you run Wireshark as Administrator, but this is discouraged. See the CapturePrivileges page on the wiki for more details.
17-02-2014 10:22 PM
To this end, I feel further investigation is probably fruitless and I am not going to put much more effort in, unless plusnet want to try and get to the bottom of this. After we have finished decorating lounge I will be retiring the 582n and installing the billion.
18-02-2014 12:02 AM
Unless PlusNet confirms that they require more testing & shows interest into this / these issue(s)
I also feel as though it will be a complete waste of time to continue further testing / since PlusNet is not wanting to look for a root cause / fix etx
I also feel that it is actually cheaper for PlusNet to send out new router(s) on a whim rather than find a fix
Therefore breaking their own Motto
Quote We'll do you proud
Please live up to your Motto PlusNet
Or
Have you fell foul of the bigger you get the less you actually care about your consumer market (Curse) syndrome?
18-02-2014 11:12 AM
Ex-Broadband Service Manager
18-02-2014 12:11 PM
Cheers
Eserim
PS - and just a thought, as my current ADSL Modem/Router has LAN ports, could I just not plug this into the BT Modem, disable the ASL stuff and use it purely as a router?
