What the hell is going on with Plusnet?
Beermonsta
For almost a year Ive had flawless broadband, and within 2 weeks its turned to a useless connection, one minute I can load webpages, next minute, no connection.....Ill be surprised if I can post this without it going into 'Limited' mode!
All my telecoms equipment is new or less than a year old, new master socket (3 months old), the line was repaired by the ultimately useless Openreach, 6 weeks back and my wifi card is showing as working correctly and a few days back I contacted you via livechat regarding this problem and a solution was fired down the line to correct the stability problem....now its back 'Your DNS is not available', when your working from home and reliant on a stable internet connection to upload completed work.....you aint 'doing me proud' at the moment
6 times in 10 minutes its cut out, I also have a quiet phone connection and my router is set to select the less a used channel.
13 REPLIES 13
Beermonsta
Re: What the hell is going on with Plusnet?
Well after a dumbass live chat session which the agent closed the session after I threatened to cancel and go to another provider, nothing has changed, once again Ive checked the master socket, router, quiet line checks and my neighbour who works for Openreach even used his off time to check and climb up the damn pole.....nothing on my side.....its your side Plusnet and if this continues today Ill will have to seek out other ISP's, because is becoming a pain and its effecting my income. Sort it
MattyC
Champion
Fixes: 46
There's definitely something wrong here:
If you raise a ticket at faults.plus.net, then I'll ensure that it's picked up for you. Feel free to give me a nudge once done.
Matty
Beermonsta
I dont even have the stability to raise one, its been down 6 times in the last 10 minutes, my gear is good, its your side
Ticket raised eventually, 6 dc's while filling in the questionnaire!
Beermonsta
Question #137672508
MattyC
Champion
Fixes: 46
Thanks, I've gotten that updated for you.
Matty
Beermonsta
Got your message, but once again, its not my end, ive done the quiet test the router test, rebooted the router, my gear is virtually brand new, next door OR engineer climbed up the pole and had a look at our internal wiring, nothing! If you book an engineer I will bill Plusnet, because my wiring is tiptop as my neighbour says
Chris
Legend
Fixes: 168
We won't book an engineer without you agreeing to the terms on the ticket and we certainly wouldn't accept a bill for it I'm afraid.
An engineer will investigate from your premises back to the cab/exchange, that's why one has been requested.
Beermonsta
Well Plusnet will accept the bill, because ill withhold funds until the OR bill is paid for, if that means going with another isp, im not paying another extortionate openreach bill, the last one was 150 quid
glloyd
There will be no bill if the fault is outside your premises. You either want the fault fixed or you don't. If you do an engineer will have to be booked. Changing ISP will only transfer your problem to them and they will still have to call out an engineer to fix it.
Beermonsta
Dont think so glloyd, wind your neck in, ill be on fttp
So your neighbour's a BTOR engineer, that's handy, so save yourself some time and get him to fix it.
MattyC
Champion
Fixes: 46
FTTC shows as available at within your locality actually and is generally much more likely to be free from faults. FTTP is highly unlikely to ever be available in the property that you're in now as it's always one or the other.
MattyC
Champion
Fixes: 46
Just to add to this:
In the unlikely event that a charge is applied, it'll be around a couple of months after the fault is resolved, once we've reviewed the case and objected to it if found to be unfair.
