What speed am i capable of? info included
- What speed am i capable of? info included
03-10-2010 10:20 PM
Ta
Uptime: 0 days, 13:42:18
DSL Type: G.992.3 annex A
Bandwidth (Up/Down) [kbps/kbps]: 444 / 4,686
Output Power (Up/Down) [dBm]: 13.0 / 0.0
Line Attenuation (Up/Down) [dB]: 29.5 / 47.0
SN Margin (Up/Down) [dB]: 17.0 / 1.0
Loss of Link (Remote): 0
FEC Errors (Up/Down): 0 / 2,041,451
CRC Errors (Up/Down): 0 / 738
HEC Errors (Up/Down): 0 / 597
Re: What speed am i capable of? info included
03-10-2010 10:22 PM
/edit - my bad, I read it back to front! It's 5,536kbps not 8Mb >.< Lucky Oldjim was around
03-10-2010 10:26 PM
If you connect to the test socket does the sync speed increase
03-10-2010 10:45 PM
Thanks for your replys
Uptime: 0 days, 0:02:21
Bandwidth (Up/Down) [kbps/kbps]: 444 / 4,185
Line Attenuation (Up/Down) [dB]: 29.0 / 46.5
SN Margin (Up/Down) [dB]: 20.5 / 6.5
FEC Errors (Up/Down): 0 / 34
CRC Errors (Up/Down): 0 / 0
HEC Errors (Up/Down): 11 / 0
jim:quote
03-10-2010 10:51 PM
Only ask as i actually paid the £49.99 for a new line but when the bt engineer came to install it he said there was no piont as there was allready a working line here and then left.
03-10-2010 11:17 PM
The speed is a bit lower with a much better noise margin so at first glance there doesn't seem much point in looking at your internal wiring although the fact that your noise margin dropped from the 6dB default to 1dB would indicate a noisy line which you can do very little about.
If you can resync at the test socket during daylight hours it will show if there is much improvement. using it but I suspect not.
03-10-2010 11:38 PM
Can i get adsl2+ as i see using samknows it says the following.
BT ADSL broadband availability
You are connected to the Nuneaton telephone exchange.
ADSL is available in your area
Your exchange is also enabled for ADSL Max services
Your exchange is also enabled for ADSL2+ services
According to BT Wholesale, your phone line should be able to support
up to 2Mbps via ADSL
7Mbps or greater ADSL connection via ADSL Max
13Mbps or greater via ADSL2+
Standard ADSL RAG results
You can receive 2Mbps ADSL
You can receive 1Mbps ADSL
You can receive 512kbps ADSL
You can receive 256kbps ADSL
03-10-2010 11:57 PM
With an downstream attenuation of 46.5dB the maximum sync speed you are likely to see is around 6Mbps. Kitz reckons that is for a line length of 3.4km, say 2.4km from the exchange. Is that about right?
04-10-2010 10:08 AM
Well i'm gutted my speed is so slow considering i used to live further away and was getting nearly 5mb from bt.
Can't my line speed be increased? It shows as 2500, was 3000, have'nt had any drop outs of loss of signal, have rebooted a few times to get a better sync speed though, i was on about 350 with a line speed of 3000, all the time now im stuck at 270kbs download speed, it's just not fast enough for my needs :(, can't even watch bbc i player in had , only really got the internet for my 3dtv and its online apps but sadly i'm living a life of constant buffering, is'nt there anything that can be done if i pump some more money into it?
04-10-2010 4:24 PM
Once your 10 day training period is complete I suggest raising a speed fault at http://faults.plus.net/ and working through the questions.
