What sort of download speed should I be getting?
- Re: What sort of download speed should I be gettin...
23-05-2008 6:43 PM
I moved over to Plusnet (from Metronet) on 6/5/08 and my speed is still showing as 'not set' - how long does it take? and what difference does it make.... My d/l speeds are not particularly great.
BT
IP profile for your line is - 5500 kbps
DSL connection rate: 448 kbps(UP-STREAM) 6560 kbps(DOWN-STREAM)
Actual IP throughput achieved during the test was - 3505 kbps
PN
Your High-speed Broadband Service
Your current broadband speed is Not Set Kbps
pd
BT
PN
pd
Message 1 of 2
(895 Views)
1 REPLY 1
Re: What sort of download speed should I be getting?
23-05-2008 7:14 PM
I suggest you give PlusNet CSC a ring and raise this problem with them. The call waiting time at the moment shows as 4 minutes max.
You have an IP Profile of 5500kbps and have had this for several days (I assume); the value shown in High Speed Broadband Service should be identical to that. The CSC can fix that instantly but you would have to disconnect/reconnect to make use of it.
It's possible the actual speed measured in the BT test is on the low side because the network is busy.
David
Message 2 of 2
(256 Views)
