What is interleaving?
- Re: What is interleaving?
21-12-2009 3:04 PM
21-12-2009 3:18 PM
Hope that helps,
21-12-2009 3:29 PM
21-12-2009 3:40 PM
whats your line stats? and we can advise how well your line should run on fastpath, if you can find the error rate stats as well that will give a better idea how well your line will cope on fastpath.
guide here on how to find the stats on your router http://www.kitz.co.uk/adsl/frogstats.php
if you go to the help assistant in the member centre you will find a max dsl interleaving ticket to request interleaving be turned off, thats if matt hasnt all ready raised one for you
21-12-2009 4:06 PM
Quote from: Addnan I am quite a die hard gamer, so can I have it switched off please
It's already switched off.
21-12-2009 4:07 PM
...if you hadn't been on fastpath since, well, as long as this screen of information on the BT site reports.
So, Addnan - apparently interleaving is already off
EDIT: as Bob says.
21-12-2009 4:08 PM
21-12-2009 4:10 PM
would it be a good idea to put the request in to insure the DLM dosent in its werid wizdom switch to interleaving on why its in auto mode
21-12-2009 4:14 PM
@ASBO - I suspect it'll be alright and stay on opt-out to be honest.
21-12-2009 4:17 PM
Quote I'd guess you were on fastpath with sky, so when we migrated you across it was done on a like for like basis.
never knew you was so proactaive like that, unless jameseh placed the order.
did think it would be strange for the dlm to run on fastpath if it was set to auto mode
