What has happened to my latency?
- Re: Ofcom and Samknows Broadband Performance Testi...
26-04-2011 4:37 PM
It has stayed at that level since. I'm on pcl-ag05
Re: What has happened to my latency?
26-04-2011 4:46 PM
Downstream
Connection Rate: 8128 Kbps
Line Attenuation: 20 dB
Noise Margin: 10 dB
Max Rate: 9920 Kbps
Interleave CRC: 0
Interleave FEC: 0
Interleave HEC: 0
Fast path CRC: 39
Fast path FEC: 0
Fast path HEC: 0
Superframes: 27034559
Upstream
Connection Rate: 832 Kbps
Line Attenuation: 13 dB
Noise Margin: 13 dB
Max Rate: n/a
Interleave CRC: 0
Interleave FEC: 0
Interleave HEC: 0
Fast path CRC: 98
Fast path FEC: 0
Fast path HEC: 0
Superframes: 27038099
26-04-2011 4:56 PM
Re: Ofcom and Samknows Broadband Performance Testing
26-04-2011 6:50 PM
26-04-2011 10:06 PM
My graphs flat-line throughout the period, and are on ptn-ag03. Downstream spec is the same (8128 without interleaving), but vanilla upstream rate at 448.
However, my last re-connection was on the 11th April, when I too saw a shift in latency. Much smaller than yours, but noticeable.
That graph shows a swap from pcl-ag7 to ptn-ag03.
Using FTTC since 2011. Currently on 80/20 Unlimited Fibre Extra.
26-04-2011 11:41 PM
Attached graph shows how successful this was!
27-04-2011 9:10 AM
So how do you explain this?
28-04-2011 12:13 PM
Any idea of the IP that the pings come from?
28-04-2011 1:29 PM
- Pinging the actual gateway gives more variation from ping to ping than pinging something beyond with a short directly peered route eg bbc.co.uk. I put this down to ICMP ping packets being a low priority task for a router and the gateways are busy passing traffic.
- When on ADSL- Max I had a solid 8-9ms to bbc.co.uk
- Now I've migrated to ADSL +2 its anything between 12ms and 22ms (consistent ping to ping, variation is day to day). Checking with ping to PlusNet gateway confirms bbc.co.uk is a reliable ping return destination.
NB. My router says 'fastpath' both for ADSL MAx and ADSL +2.
I think that ADSL +2 may not be such a consistent perfomer for latency. Given there is a marginal synch increase in my case (from ~7Mbps to ~8Mbps) I wonder if ADSL-MAX may be better. Can you have upstream un-capped for > 443kbps upstream on MAX?
28-04-2011 1:54 PM
28-04-2011 2:53 PM
The latency has stayed at it's normal 12-14ms level since dropping back on Wednesday morning.
