What does this mean?
- Re: What does this mean?
02-01-2013 10:11 AM
What does the below mean?.......is it of any interest to me?.......
"We have just increased the capacity of our WBC(21CN) broadband host links by a further 5.35Gbps. It's these host links that we use to deliver bandwidth to our broadband customers.
As part of the increase we will also disable a number of IPSC (20CN) end points to free them up to be converted to WBC end points.
We've activated this extra capacity in line with the current budget, our new products, customers' usage habits and our projected growth in customer numbers."
KR's
Alex
KR's
Alex
Message 1 of 9
(1,961 Views)
8 REPLIES 8
02-01-2013 10:20 AM
As the description says we've increased the capacity of our network for 21CN connections (which is what you have).
This is something we need to do regularly as our customer base expands to make sure everyone has a the best possible experience of the service.
Message 2 of 9
(1,047 Views)
02-01-2013 10:22 AM
Thanks Adam......but in real terms..... as far as I am concerned what does it mean to be? Faster connection?
Just a bit technical for me (the jargon)
Alex
Alex
Message 3 of 9
(1,047 Views)
02-01-2013 10:26 AM
Not necessarily, I'd look at it from the other way around, it's essential house keeping. If we didn't do it, you'd notice slower speeds when using the internet for certain things at certain times of day (i.e when the network is busier).
A good analogy to use would be us making more "room" on our network as new customers join us and so our network grows to accommodate.
Adam
Adam
Message 4 of 9
(1,047 Views)
02-01-2013 10:28 AM
Surely it means providing enough headroom so that your speed can be maintained - it avoids congestion on the system and allows more connections (I think).
Message 5 of 9
(1,047 Views)
02-01-2013 10:59 AM
Thanks Adam! Makes sense to me now.
KR's
Alex
KR's
Alex
Message 6 of 9
(1,047 Views)
02-01-2013 1:00 PM
A simple analogy would be a water supply to a town through a 6" pipe.
People will notice a reduction in flow at times of high demand so the water company can either increase the size of the pipe or lay extra pipes.
Message 7 of 9
(1,047 Views)
02-01-2013 5:58 PM
And following on from that what they have done is take some IPSC pipes and used them for WBMC instead. Presumably because with the recent number of newly WBC-enabled exchanges the IPSC traffic has declined considerably. (Plus maybe some more WBMC as well).
Message 8 of 9
(1,047 Views)
02-01-2013 6:07 PM
IPSC WBMC WBC IPSC........F*S C'mon give a guy a chance!
Message 9 of 9
(1,047 Views)
