What do you do if connecting to the test socket works?
- Re: What do you do if connecting to the test socke...
10-07-2012 8:34 PM
So as things stand there is a straight choice between telephone extensions and lousy broadband or good broadband but no telephone extensions. Is there a way forward that avoids this trade-off? For example, if BT could be persuaded to swap the existing faceplate for an ADSL faceplate is that likely to work?
Re: What do you do if connecting to the test socket works?
10-07-2012 8:41 PM
First thing is to get rid of the ring wire
I don't know how good the BT filtered faceplate is but I am very happy with my ADSL Nation one.
However neither of them are much good if there are more than two wires connected to the faceplate
10-07-2012 9:10 PM
Yes, there is another way - if you know what you are doing.
You wire your entire house's phone system in good quality solid core Cat5e Network cabling....you only need to use one of the 4 pairs in a standard cat5 cable.
I've got some 35 meters of the stuff in a rather tortuous path between the NTE5 and my study at the other end of the house.
You need to decide the colour coding you are going to use of the wires in the cat5 and then stick rigously to it throughout the house.
It will far exceed the quality of any existing internal phone wiring...some of which, sad to say, will be of a truly dire quality and of a type not suited in anyway for high frequency data transmission.
Cat 5 will also exceed by a fair margin the quality of the dropwire from the BT pole to the NTE5.
Even new houses are not immune from the problem of grotty internal house phone wiring. It has been known for "electricians" to wire up the phone extensions in the house in low grade multi-strand non twisted pair burglar alarm cable - OK for voice but totally unsuitable for ADSL/data transmission.....All buried in the wall of course...nice!
10-07-2012 9:28 PM
If the existing wiring is not a 2 pair cable (ie. 4 wires) coloured Blue/white trace & White/blue trace and the second pair Orange/white trace & White/orange trace then it is not CW1308 spec. cable.
If there are 4 wires in the cable coloured Blue, Orange, Green and Brown then this is very old standard GPO cable and needs replacing as it is not twisted pair..
If the cable is already CW1308, the the only wires that should be connected are the Blue/white & White/blue to terminals 2 & 5 at the rear of the NTE5 faceplate and all extension sockets. The other important thing is to use decent filters of the Rat's tail type. Filters that look like solid block splitters are inferior quality and will degrade broadband performance.
The other option is a complete re-wire job as I've just posted here.
Edit: No plug in extension cables should be used between any socket and a filter or between the filter and the modem/router unless the later is a special quality twisted pair type (not supplied with the modem/router).
10-07-2012 9:38 PM
I don't understand the need for telephone extension sockets any more, with the convenience of modern cordless phones.
10-07-2012 10:01 PM
Also some NTE5's are in very small hallways and no power socket, so it's not always a convenient solution (and could result in a safety issue with trip hazards).
10-07-2012 10:06 PM
If that fails I can, I suppose, disconnect all three wires to follow Purleigh's suggestion.
10-07-2012 10:11 PM
10-07-2012 10:12 PM
10-07-2012 10:51 PM
10-07-2012 10:52 PM
10-07-2012 10:55 PM
Quote from: ReedRichards Is there a way forward that avoids this trade-off?
The new-style "VDSL" interstitial plate is pretty good. I have one now and it works a treat on ADSL2+.
Here for example: http://www.broadbandbuyer.co.uk/Shop/ShopDetail.asp?ProductID=13095
10-07-2012 11:47 PM
Quote from: HPsauce
But the note on the linked page says this:-
Please Note: This BT VDSL iPlate is suitable for all FTTC Fibre Broadband connections that have been installed by a certified BT engineer. It is not suitable for use with Virgin Media Fibre Broadband or any ADSL 2/2+ service.
11-07-2012 11:01 AM
Quote from: HPsauce Surely the terminals are labelled with SOME sort of identification?
Surely indeed - but because they have wires attached it's not possible to get the faceplate far enough away from the socket to see the identification.
11-07-2012 11:07 AM
