What can I expect from 21CN?
zebop917
Although I live on the edge of a decent-sized city - Exeter - my phone line comes through a satellite exchange. This has few residential customers and so has never had any LLU presences to bring down prices. So, it's always been "garden variety" up-to-8Mb/sec ADSL. Since moving to PlusNet, my actual speed has always been around 5.2-5.6Mb/sec. Well, it's OK to stream HD video but everywhere else on the main exchange does much better. However, I now see from SamKnows that the exchange has now been upgraded to 21CN WBC status. Whoopee - but what does that actually mean? Am I likely to see any benfits from this?
9 REPLIES 9
Oldjim
Resting Legend
Fixes: 63
Re: What can I expect from 21CN?
:Post the stats from your router as described here http://community.plus.net/forum/index.php/topic,96155.0.html
zebop917
ADSL Link             Downstream Upstream
Connection Speed     6752 kbps         448 kbps
Line Attenuation     46.0 db         24.5 db
Noise Margin             6.5 db         26.0 db
Current line profile from the BT site is 5500 kbps.
Phil
Oldjim
Resting Legend
Fixes: 63
Probably an increase of 1,000kbps or more
http://www.kitz.co.uk/adsl/max_speed_calc.php
jelv
Fixes: 10
... and probably a doubling of upload speed.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
MatthewWheeler
Fixes: 479
Hi there.
We can place the order to move you across now which would complete in 5 to 7 working days.
If your interested just reply to this message
 Matthew Wheeler
Fixes: 160
Quote from: Oldjim
Jim,
I'd be cautious with expectation setting.  The page you referred to states...
It is also worth pointing out that attenuation is calculated differently for adsl and adsl2+, and its not unusual to see an increase of 3-4 db when moving from adsl1 to adsl2+.
This page suggests 6818 @46dB (ADSL1 attenuation).  If we take the above statement at face value, then @49dB gives 5568.  Experience suggests that good lines can though deliver significantly better than Kitz advises.
Sight of the op's error counts would be useful.
Oldjim
Resting Legend
Fixes: 63
I was going more by experience and this
Fixes: 160
Jim,
I understand your call, but the OP's ADSL 1 line is in that zone where the difference could be minimal, which is why I also said if the line is good, it might achieve better than the Kitz figures.  This is I suggest right in the middle of such it and see space!  Shocked
Kevin
ejs
Aspiring Hero
Fixes: 25
I thought the kitz max speed calc works on input of ADSL1 attenuation, so you don't add to the attenuation if you want an ADSL2+ estimate.
