Website check
30FTTC06
Fixes: 4
Website check
I'm having trouble getting to pgl.Yoyo.org Just Me ?
18 REPLIES 18
Oldjim
Resting Legend
Fixes: 63
Re: Website check
not just you and I am not using Plusnet DNS servers
Just tried http://downforeveryoneorjustme.com/ and got error 502 Bad Gateway so that site is screwed as well
30FTTC06
Fixes: 4
Re: Website check
Cheers Oldjim.
30FTTC06
Fixes: 4
Re: Website check
lol... yeah i just tried this one as well... http://downforme.org/ seems to work on that.
Pettitto
Fixes: 5
Re: Website check
Chris Purvey is speaking to Ops about a few issues at the moment. We'll let you know if we find anything.
npr
Fixes: 9
Re: Website check
I've tried through a few proxy's and still can't access the site.
So doubt it's a PN issue.
Fixes: 1,482
Re: Website check
tried through a VPN and failing..
30FTTC06
Fixes: 4
Re: Website check
Thanks for taking the time all.
TORPC
Re: Website check
Quote from: 11110_110
Same here, although it claims it is only down for me
Therefore I would not rely on it too much Wink
I would ask the host if they are having any known issue(s)
chrispurvey
Re: Website check
We've not been able to replicate this issue, are you able to provide a traceroute?
Oldjim
Resting Legend
Fixes: 63
Re: Website check
Tracing route to pgl.yoyo.org [95.172.9.82]
over a maximum of 30 hops:
  1    57 ms    99 ms    99 ms  192.168.1.254
  2    79 ms    34 ms    83 ms  lo0-central10.ptw-ag03.plus.net [195.166.128.197]
  3    34 ms    34 ms    34 ms  link-a-central10.ptw-gw01.plus.net [212.159.2.152]
  4    34 ms    34 ms    33 ms  xe-4-3-0.ptw-cr01.plus.net [212.159.0.244]
  5    35 ms    34 ms    34 ms  ten0-1-1-2-t40-mse1.router.uk.clara.net [195.66.224.66]
  6    35 ms    34 ms    34 ms  tengige0-0-0-0-gs2-mse1.router.uk.clara.net [195.157.3.22]
  7    35 ms    34 ms    34 ms  tengige0-1-1-0-gs2-mse2.router.uk.clara.net [195.157.3.26]
  8    34 ms    34 ms    34 ms  g7-1-gs2-ar2.router.uk.clara.net [195.157.6.58]
  9    34 ms    34 ms    33 ms  po1.br1.str.uk.idllt.net [80.168.71.254]
10    34 ms    34 ms    34 ms  po3.br2.str.uk.idllt.net [78.40.33.10]
11    35 ms    34 ms    33 ms  gi1-48.ir2.str.uk.idllt.net [78.40.33.18]
12    *        *        *    Request timed out.
13    *        *        *    Request timed out.
14    *
TORPC
Re: Website check
[code= CMD File = tracert]
C:\Windows\system32>tracert pgl.yoyo.org
  1    68 ms    70 ms    96 ms  dsldevice.lan [192.168.1.254]
  2    77 ms    33 ms    38 ms  lo0-plusnet.ptn-ag04.plus.net [195.166.130.17]
  3    50 ms    31 ms    46 ms  link1-plusnet.ptn-gw01.plus.net [84.92.7.92]
  4    32 ms    39 ms    39 ms  xe-1-2-0-141.ptw-cr01.plus.net [212.159.1.168]
  5    38 ms    31 ms    46 ms  ten0-1-1-2-t40-mse1.router.uk.clara.net [195.66.
224.66]
  6    32 ms    32 ms    31 ms  tengige0-0-0-0-gs2-mse1.router.uk.clara.net [195
.157.3.22]
  7    32 ms    31 ms    32 ms  g8-1-gs2-ar2.router.uk.clara.net [195.157.6.54]
  8    54 ms    51 ms    52 ms  po1.br1.str.uk.idllt.net [80.168.71.254]
  9    32 ms    33 ms    32 ms  78.40.33.14
10    35 ms    88 ms    38 ms  78.40.33.6
11    *        *        *    Request timed out.
14    *        *        *    Request timed out.
15    *        *        *    Request timed out.
16    *        *        *    Request timed out.
17    *        *        *    Request timed out.
18    *        *        *    Request timed out.
30    *        *        *    Request timed out.
Trace complete.
C:\Windows\system32>[/code]
30FTTC06
Fixes: 4
Re: Website check
http://pgl.Yoyo.org
[tt]Host                                Loss%  Snt  Last  Avg  Best  Wrst StDev
1. 192.168.0.254                    0.0%    5  52.0  62.4  52.0  72.8  8.2
2. lo0-central10.ptw-ag03.plus.net  0.0%    5  16.4  17.6  16.4  20.3  1.4
3. link-a-central10.ptw-gw01.plus.n  0.0%    5  16.1  16.7  16.1  17.1  0.0
4. xe-4-3-0.ptw-cr01.plus.net        0.0%    5  16.2  16.2  15.9  16.5  0.0
5. ten0-1-1-2-t40-mse1.router.uk.cl  0.0%    5  16.9  16.9  16.5  17.1  0.0
6. tengige0-0-0-0-gs2-mse1.router.u  0.0%    5  16.8  17.0  16.8  17.2  0.0
7. tengige0-1-1-0-gs2-mse2.router.u  0.0%    4  16.9  17.0  16.8  17.0  0.0
8. g7-1-gs2-ar2.router.uk.clara.net  0.0%    4  16.8  53.8  16.7 164.6  73.9
9. po1.br1.str.uk.idllt.net          0.0%    4  17.0  26.9  17.0  56.7  19.8
10. po3.br2.str.uk.idllt.net          0.0%    4  17.4  17.1  16.5  17.4  0.0
11. gi1-48.ir2.str.uk.idllt.net      0.0%    4  17.3  22.4  17.3  34.4  8.0
12. ?
[/tt]
chrispurvey
Re: Website check
I can't see any issues with them, they're well outside our network. I'll get the network guys to take a look to see if anything is amiss.
TORPC
Re: Website check
Hi Chris
Does the website in question, fully load on your side ?Huh
