Webcam
- Webcam
Webcam
07-08-2012 10:06 AM
Re: Webcam
07-08-2012 10:32 AM
Re: Webcam
07-08-2012 10:44 AM
Quote from: BRABUS Put a link up to the webcam and we can all see if we have the same issue as you. We can try at work and then when we get back home onto PN.
Thanks Brabus.I do not know how to put up link but,If you go to Dawlish.com,go to Discussion page and on the list you will see Dawlish seawall,click on that.Scroll down until you see Dawlish webcam embedded.There Is a short ad.(although sometimes you can skip ad.),and there you will see the Dawlish seawall webcam.
Re: Webcam
07-08-2012 10:48 AM
http://cdn.livestream.com/embed/RCDawlish?layout=4&color=0xe7e7e7&autoPlay=true&mute=false&iconColor...
Re: Webcam
07-08-2012 10:50 AM
Re: Webcam
07-08-2012 10:52 AM
Re: Webcam
07-08-2012 10:54 AM
Now I'm going to sit here waiting for a train
Armchair trainspotting
Re: Webcam
07-08-2012 10:56 AM
Quote from: davidj60 Not smooth for me either - I'm on a 6.5Mb connection. Quite "jerky" when the train passed!!!
Thanks for reply David.That`s exactly what I have got but I do not know what connection I am on.A plusnet moderator says It Is smooth for him.
Re: Webcam
07-08-2012 10:58 AM
Re: Webcam
07-08-2012 10:59 AM
Quote from: Strat http://cdn.livestream.com/embed/RCDawlish
There Is one due In 6 minutes.It should come towards camera.
Re: Webcam
07-08-2012 11:00 AM
Re: Webcam
07-08-2012 11:01 AM
Quote from: Oldjim Train going past was a bit jerky but I put that down to the frame rate of the webcam as the bit rate isn't high enough for it to be smooth
Works fine for some people though.
Re: Webcam
07-08-2012 11:04 AM
Re: Webcam
07-08-2012 11:06 AM
Re: Webcam
07-08-2012 11:11 AM
