Want to reduce box count
- Re: Want to reduce box count
11-06-2014 5:05 PM
Hi, I'm a second day plusnet user and happy so far, except the hardware count. I used to be on regular broadband where my Netgear DGN2200 was able to handle ADSL modem and wireless router duties. I'm now on fibre and can just about accommodate the two box business of BT modem + 582N router but after finding the supplied router "somewhat lacking" in the wireless department I ended up having to add in my old Netgear router as an extra wireless access point. That's three blinkin' boxes now.
The obvious 2 box option is to replace both the 582N and the Netgear router with a decent WLAN enabled wireless router - any suggestions?
But is there a 1 box option that replaces the BT modem as well?
Message 1 of 7
(1,253 Views)
6 REPLIES 6
11-06-2014 5:26 PM
BT Homehub 5
Edit: You might find http://www.ispreview.co.uk/index.php/2014/01/broadband-router-options-uk-fttc-isps-integrated-vdsl-m... helpful.
I've seen a lot of good things said about the Asus DSL-N66U N900
Message 2 of 7
(660 Views)
11-06-2014 10:22 PM
I'd recommend the BT Home Hub 5 iv'e been using one since last november and never had any issues with it wireless range is excellent especially on the 5Ghz band and all fairly easy to setup.
Message 3 of 7
(660 Views)
12-06-2014 8:10 AM
Looking at the spec for the Netgear, bit confusing as sometimes it refer to it as N300, that the port adjacent to the ADSL can be used as a WAN port. If that's the case you can used the Netgear in place of the supplied PN router.
Message 4 of 7
(660 Views)
12-06-2014 8:25 AM
http://www.netgear.co.uk/home/products/networking/dsl-modems-routers/dgn2200.aspx#tab-techspecs says "Ethernet WAN—Easy Upgrade to cable/fiber"
Message 5 of 7
(660 Views)
12-06-2014 9:39 AM
Ah ha! - good spotting on the WLAN port. That should be just what I need, for now at least. Just my luck that in the two times I tried to get it to do PPPoE I randomly chose the wrong port.
Message 6 of 7
(660 Views)
12-06-2014 10:33 AM
And back to square one...
The latest DGN2200v4 does have a WLAN port. My DGN2200v1 does not.
http://kb.netgear.com/app/answers/detail/a_id/23900/related/1
Message 7 of 7
(660 Views)
