Voyager 210 ADSL Router problem
- Voyager 210 ADSL Router problem
27-06-2008 9:37 AM
I have just finished rebuilding my computer after a crash and I could not connect to Internet with Voyager 210, although it worked OK for nearly a year. I was using Ethernet connection and, in desperation, I installed USB drivers and connected the USB lead. That worked, but now the router works only if both Ethernet and USB leads are connected.
How can I revert to ethernet only connection?
Many thanks,
Alex
Many thanks,
Alex
Message 1 of 6
(1,269 Views)
5 REPLIES 5
Re: Voyager 210 ADSL Router problem
27-06-2008 9:51 AM
Try unplugging both USB and ethernet cables from the PC, then uninstall the BT Voyager drivers, reboot the PC, then plug only the ethernet cable back in. You should see a popup in the bottom right hand corner telling you a local area connection is now connected - you can confirm this by clicking start -> run, typing 'cmd' (without quotes) into the box and then clicking OK then in the new box typing 'ipconfig' (again without quotes) and hitting enter. You should find that connection 'Local Area Connection' has been issued an IP address of 192.168.1.2 and has a default gateway of 192.168.1.1
Hope that helps, please let us know if not.
Message 2 of 6
(435 Views)
27-06-2008 3:38 PM
Quote from: orbrey Try unplugging both USB and ethernet cables from the PC, then uninstall the BT Voyager drivers, reboot the PC, then plug only the ethernet cable back in. You should see a popup in the bottom right hand corner telling you a local area connection is now connected - you can confirm this by clicking start -> run, typing 'cmd' (without quotes) into the box and then clicking OK then in the new box typing 'ipconfig' (again without quotes) and hitting enter. You should find that connection 'Local Area Connection' has been issued an IP address of 192.168.1.2 and has a default gateway of 192.168.1.1
No, that did not work. I did not get the popup that the local connection is connected. I then just connected USB lead and the system automatically "installed" the driver and I got connected to Internet. By the way, I am running Win XP pro. Does that make any difference?
Alex
Message 3 of 6
(435 Views)
27-06-2008 3:49 PM
Alex,
Can you uninstall the drivers, reinstall using the cd, then plug in the usb lead when prompted and then give it another shot?
Message 4 of 6
(435 Views)
27-06-2008 10:28 PM
Did you have to re-install windows?
If so there is a chance the drivers for your network card were not installed automatically.
Check your devices in device manager, right click my computer > properties > hardware tab > device manager what is under network adapters?
Message 5 of 6
(435 Views)
29-06-2008 4:01 PM
Thank you all for advice. It seems that the NVidia CD contained Ethernet driver and I connected to Internet before completing the re-build. Once the driver was installed, I got the message at the bottom right of the screen "Safe to Remove hardware" and clicking on it showed it to mean USB lead.
All now back to normal. Thanks again,
Alex
Alex
Message 6 of 6
(435 Views)
