Volunteers for 21CN Premium Services
- Volunteers for 21CN Premium Services
- « Previous
- 1
- 2
- Next »
Re: Volunteers for 21CN Premium Services
21-05-2009 10:34 AM
21-05-2009 5:11 PM
do you know the full detials at the mo of the options your going to be trialing out of that list on the link i posted. ?
As said before the real time qos for xbl traffic would be somthing i would try but also on that link the banded sync rates also tikels my fancy but as its sync related i would want to know as much about it as possable before giving it ago
21-05-2009 5:12 PM
As far as I'm concerned, it was literally just enhanced care and the elevated traffic priority on the BT network.
I'll catch up with Fletch on Tuesday though.
21-05-2009 5:19 PM
enhanced care leaves to much to the imagination and i wouldnt risk it for biscuit based on that discription
21-05-2009 5:22 PM
Enhanced Care gives you an SLA within BT Wholesale. Next day engineer visits and fault updates within 4 hours, I believe.
21-05-2009 5:31 PM
would BT's i dont care about the rest of are customers package(enhanced care) get them sort my drop wire out and master socket with out me having to capture a rodent to get to chew through my wire
21-05-2009 5:33 PM
I will be able to confirm next week.
21-05-2009 5:37 PM
you sure dont crack under interrogation
21-05-2009 10:59 PM
22-05-2009 9:23 AM
Holidays should be banned! (Apart from mine)
23-05-2009 11:56 AM
01-06-2009 10:04 PM
Quote from: Jameseh Holidays should be banned! (Apart from mine)
Did Fletch come back from his hols?
I'm sure I PM'd him, but I can't find the message in my outbox. Probably I forgot to tick the box...
- « Previous
- 1
- 2
- Next »
