Vidzone buffering
- Vidzone buffering
Vidzone buffering
21-08-2009 11:08 AM
I would of thought that the 2Mb speed would be sufficient enough to stream the youtube quality videos and casette tape quality audio that vidzone delivers.
Firstly could anyone else on the unlimited package try out vidzone since youtube runs fine, even on HD.
PlayStation Video Store
19-11-2009 3:10 PM
Bob
Re: PlayStation Video Store
19-11-2009 3:17 PM
19-11-2009 3:20 PM
Bob
19-11-2009 3:23 PM
19-11-2009 3:52 PM
edit. am not sure about zune on the xbox but last fm seems to be picked up right from the first day of launch. lovely port 3074
19-11-2009 4:03 PM
Quote from: ASBO thank god i dont own a ps3
I do, every day!
19-11-2009 7:03 PM
Quote from: adiewoo I guess it will require a wireshark capture at some point to help enable them to sort it out.
Any expert PS3 Wiresharkers out there?
Bob
20-11-2009 9:52 AM
20-11-2009 11:57 AM
first of you need laptop or PC (laptop easyer of cause) with both LAN and wireless (or double lan if your posh) go to manage network connections and highlight both you lan and wireless adapters, right click and select bridge connections (make sure both adapters are not in use ie disconnect your wireless and leave the ethernet cable unplugged) now you should see a 3rd adapter pop up in the list called bridged.
now reconnect your wireless and this bridged connection will have all the ip ect info now where the wireless will give no info when you check its staus. now check your PC has connection to the internet if so plug your ethernet cable in from your ps3/xbox to your pc.
if you have your ps3/xbox setup on auto to get ip ect and you cant get a connection to the net from it, manulay input the ip address, subnet and dhcp server and dns (routers ip if thats the dns server)
works every time for me the only problem i get is if i dont disconnect my laptop from the wireless when i bridge the adpaters, it still bridges them but i dont get no net and have to delete the bridge and start again, some times my xbox setup on auto grabs the info from the router and some times not but adding the info on my xbox manauly allways works.
now in wireshark goto capture, interfaces and you will most likely see 2 interfaces clocking up packets on the counter. i tend to sniff the ethernet lan instead of the wireless mac bridge as it tends to cut down on packets from your router tallking to the bridged adapter getting in your console capture.
the captures below have not got the xbox attached as am on my desktop hence why the LAN says its disconnected, also when your done with routing the console through your pc just right click that bridged adapter and click delete (again make sure your wireless and lan are not in use or it fails to delete it)
it will be slightly diffrent on xp but the method of bridging will be the same
20-11-2009 1:12 PM
I think that we need a statement from PlusNet whether they intend to support this service. If they do then I think they carry some responsibility to do the investigation and get it working.
Bob.
20-11-2009 1:27 PM
p.s when one of you finaly upgrade to the better console you will have to give me the ps3 for testing
in the past i have had pn once watching my connections traffic going over the network but the only info they told me is they could see the XBL vids ip's where limelight, i have no idea if they saw what prioity they was getting and if they can grab a capture to enable a sig to be made watching traffic like this
21-11-2009 11:59 AM
Please could we have some input from PlusNet on this - I still think that the onus should be on them to sort it out.
By the way, it's streaming ok this morning (11:45 on Saturday). Maybe that's because the network is back in "Plan A" mode?
Bob
21-11-2009 3:36 PM
am allways happy to help but not much one can do, even the mighty xbox cant morph into a ps3 or wii
Re:PlayStation Video Store
23-11-2009 1:45 PM
I've asked Tommo to do some testing on this, and see what we can do.
Being back in plan A will have made things significantly better, but we need to check what it's marked as and make sure it's correct.
