Very slow speeds (suddenly)
- Very slow speeds (suddenly)
11-06-2013 7:50 PM
hi guys, i wonder if you could take a look at my connection?
i'm getting really bad latency (over 1000ms to everywhere that i ping including www.plus.net) & download speeds are abysmal.
i have ran through the bt wholesale speed test with bizzare results:
on test 2 i am getting 0.18 Mbps download
& 0.19Mbps upload
on test 3(after logging into BT's network I got: 1.62Mbps (slightly lower than normal, usually get about 1.80 - 1.90 Mbps)
& upload of 0.01 Mbps.
have rebooted router etc. & went through the usual troubleshooting. & think it must be either a line fault, or something to do with plus-net?
i noticed that there is maintenance on the traffic management system, but this is not until tomorrow morning
can you guys have a look at my line please? what information do you need me to provide?
& 0.19Mbps upload
Message 1 of 7
(1,201 Views)
6 REPLIES 6
Re: Very slow speeds (suddenly)
11-06-2013 8:28 PM
just did a trace to google, results below:
tracert www.google.com
Tracing route to www.google.com [173.194.41.148]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms 192.168.0.1
2 1344 ms 1280 ms * lo0-central10.pcl-ag08.plus.net [195.166.128.189
3 753 ms 1410 ms * link6-central10.pcl-gw02.plus.net [84.93.249.234
4 1318 ms 1117 ms 1210 ms xe-2-2-0.pcl-cr02.plus.net [212.159.1.14]
5 1308 ms 1302 ms 1403 ms ae1.ptw-cr02.plus.net [195.166.129.2]
6 1317 ms 1361 ms 1395 ms 72.14.223.32
7 1394 ms 1332 ms * 209.85.252.186
8 1128 ms 1253 ms 1387 ms 72.14.238.55
9 1295 ms 1301 ms 1376 ms lhr08s03-in-f20.1e100.net [173.194.41.148]
Trace complete.
line fault?
Trace complete.
line fault?
Message 2 of 7
(689 Views)
11-06-2013 8:37 PM
Can you post the stats from your router - noise margin, speeds and attenuation.
Also, if you can, the reported errors and the uptime
Message 3 of 7
(689 Views)
11-06-2013 9:08 PM
Sorry for formatting issues, posted from phone
Line Status:Connected
DSL Modulation Type:ADSL_G.dmt
Annex Type:Annex A/L
Current Rate (Kbps)
Upstream Downstream
448 1920
Max Rate (Kbps)
Upstream Downstream
776 2016
SNR Margin (dB)
Upstream Downstream
11 7.1
Line Attenuation (dB)
Upstream Downstream
31.5 63.5
Errors (Pkts) 0 0
[Moderator's note by Jim (Oldjim) formatting tidied up ]
Current Rate (Kbps)
Upstream Downstream
448 1920
Max Rate (Kbps)
Upstream Downstream
776 2016
SNR Margin (dB)
Upstream Downstream
11 7.1
Upstream Downstream
31.5 63.5
Errors (Pkts) 0 0
Message 4 of 7
(689 Views)
11-06-2013 9:23 PM
You are on a long line but there isn't anything there which would give the problems you are seeing.
I think you should raise a fault at http://faults.plus.net but before doing that are the results from a wired or wireless connection - if wireless can you try wired
Message 5 of 7
(689 Views)
11-06-2013 9:53 PM
Hi, tests were done on gigabit cat5e, speeds are also abysmal over wireless, have raised a fault, thanks
Message 6 of 7
(689 Views)
12-06-2013 9:24 AM
Hi Roadrunner1024,
Our faults team will be in-touch once they've finished testing your line.
Message 7 of 7
(689 Views)
