Very Slow Download speed
- Very Slow Download speed
14-11-2010 7:38 PM
Re: Very Slow Download speed
14-11-2010 7:40 PM
14-11-2010 7:45 PM
BLYTH
Estimated line speed:
4 - Checked on 2010-05-16 23:06:58
Current line speed:
250
14-11-2010 7:57 PM
Run the BT speedtest and check the IP profile
15-11-2010 9:39 AM
Your BT profile has been dropped because of the number of disconnections. How is your connection set up? Are you in the test/master socket? Are you using an extension or extension cable?
As you can see, your connection is dropping quite a lot.
Jojo
17-11-2010 6:55 AM
17-11-2010 10:44 AM
do you have a test socket? If so, can you plug in there. Below are your last 7 days connections and as you can see there have been a lot of disconnections and this is the reason your speed is so low. Your line has been placed on a banded profile because of this which means that your router will only sync between 160k-288k until your connection stabilises. I can get this lifted once the line is stable but if you don't have a test socket and you have tried a new filter in the master socket with all other equipment removed then a fault definitely needs to be raised.
Jojo
17-11-2010 6:06 PM
17-11-2010 6:38 PM
17-11-2010 6:47 PM
Line Rate 287 Kbps 443 Kbps
Noise Margin 22.3 dB 25.7 dB
Line Attenuation 45.5 dB 25.0 dB
Output Power 0.0 dBm 13.1 dBm
