Very Slow Download's
- Very Slow Download's
30-10-2009 3:43 PM
Yesterday when I turned on my router I got my usual line rate of around 12920Kbps but things seemed slow. When I checked I was getting 2477Kbps down instead of my usual 10000+Kbps. Checked my Bt profile and it was still at 11000Kbps so I disconnected reconnected a few times and eventually got back to a near normal for me download speed.
Same thing has happened today excpt this time I've not been able to get anything better than 4633Kbps With a Bt profile of 11000Kbps.
Anyone got any ideas as to whats going on?
Re: Very Slow Download's
30-10-2009 3:48 PM
http://usertools.plus.net/@gateway
30-10-2009 4:00 PM
30-10-2009 4:19 PM
Asbo Dog
Thanks for your reply.
I'm afraid I can't use that link I'm a madasafish customer and I've not found a way to access any details like that on their web site.
30-10-2009 4:21 PM
30-10-2009 4:23 PM
We're currently looking at issues impacting our 21c customers.
30-10-2009 4:34 PM
2nd hop reads
1o0-brightview.thn-ag2.plus.net [195.166.128.89]
Jamesh
Wow thats an interesting statement. What do you meen by issues? Crap download speeds I guess.
30-10-2009 4:41 PM
We're working on it this very second.
30-10-2009 4:45 PM
02-11-2009 4:31 PM
The only thing is tha a tracert shows I'm connected via pcl-ag04.
Anyone know whats going on this time?
Re:Very Slow Download"s
02-11-2009 5:12 PM
The issues James mentioned have been fixed now, and we're not aware of anything up with PCL-AG04. Which speed test did you use, and are you the only person using the connection at the moment?
02-11-2009 5:24 PM
but for the last week or two the speed i am acheving is as low as 5000 also getting latency problems as well
regardless of what host link i am on.
02-11-2009 5:29 PM
Quote from: orbrey Hi Cogin,
i can say that the latency is still pants on both gateways after midnight, so ad be intrested in why you think the issue is fixed on the latency front, wheres your evidence of this pelease? mine says its still pants http://community.plus.net/forum/index.php/topic,80166.msg655369.html#msg655369
did you magicaly fix them on sunday or today and tested that the midnight issue is no longer there?
02-11-2009 9:46 PM
He asked me earlier - the ERX load issue was fixed on Friday, but obviously you've been having midnight latencyisues over the weekend.
03-11-2009 4:20 PM
In answer to Asbo dogs questions No I am the only one connected and I used My Broadband speed test via Madasafishes web site and Speedtest.com. I did aCheck with BT's speed test just to get my IP profile as they always report much slower downloads than the others so I don't take much notice of their reported download speed.
Todays test's Mybroadband 1020kbps down 892kbps up
Speedtest.com 0.88Mbps down 0.78Mbps up.
Before I was getting an adverage of 10370kbps down and 862kbps up
Up's ok dowm is pants. I'm going to try a few reconnects in a bit to see what happens. This started on the 29.10.09 I know because I've been doing a speed check every time I boot the router to see if ADSL2+ is actualy stable and really worth paying more money for before I have to.
I've got no idea whats happened nothing has changed my end.
