Vast Improvement To My Speed And Ping
- Vast Improvement To My Speed And Ping
25-11-2009 5:52 AM
1.de-activated my surf/Your Surf Access is currently Unrestricted
2.disconnected from internet then re-connected.
Gateway im on now is.You are currently connected to the "City Lifeline, Juniper 8" gateway. This gateway is sometimes known as pcl-ag01. Plusnet Premuim.
Of course it its 05.48 at time of posting this but im very happy with my ping and well the speed is what i should be getting anyway.
Re: Vast Improvement To My Speed And Ping
25-11-2009 7:35 AM
25-11-2009 7:51 AM
repeated disconnections can cause the Dynamic Line Management to increase your target noise margin (resulting in lower sync) so don't be tempted to keep trying for a faster sync. Normally the best thing is to try once during daylight (as noise is usually lower and you should get a better sync for a given noise margin), waiting an hour or so after it becomes light is recomended, if you don't get a good sync on the first attempt then wait a while before trying again (if your sync is not too bad then waiting until the next day is probably wise), it's better to have a day on a slightly lower sync than to get your speed knocked down by the DLM.
25-11-2009 8:12 AM
25-11-2009 9:06 AM
6550Kbps & 54ms pings
Just hope it lasts this time !!!
25-11-2009 9:51 AM
25-11-2009 12:59 PM
25-11-2009 2:30 PM
25-11-2009 3:58 PM
25-11-2009 6:51 PM
25-11-2009 7:42 PM
25-11-2009 8:12 PM
25-11-2009 8:25 PM
25-11-2009 8:34 PM
25-11-2009 8:47 PM
