VPN server on DD-WRT
- Re: VPN server on DD-WRT
02-12-2013 7:57 PM
I'm looking at getting a router so that I can use my router as a VPN server.
I was thinking about putting DD-WRT on an Asus RT-n55u or RT-n66u... would that be compaitble with Plusnet Fibre broadband?
Cheers
Cheers
Message 1 of 2
(444 Views)
1 REPLY 1
03-12-2013 10:19 AM
I'm not sure if DD-WRT is compatible with those routers but the routers themselves should be fine, yes.
If you have a dig around I'm sure you'll find posts from others using the RT-n55u
Message 2 of 2
(248 Views)
