VPN Not able to connect using Plusnet
karenjay
Hi can any one help, I cant connect to a VPN  - Always worked before switching to Plusnet. And it works at a friends house who has Plusnet!!! Help desk just say they dont support VPN!!!! Not a good start. Any suggestions appriciated. Thanks Roll_eyes
6 REPLIES 6
Fixes: 1,483
Re: VPN Not able to connect using Plusnet
Are you using the Thomson router supplied by PN?
karenjay
yes!
Fixes: 1,483
Have a read of this you'll need to change your routers firmware
karenjay
Great. Thanks for your help  Smiley
Fixes: 1,483
No worries, and welcome to the forums btw Smiley
jelv
Fixes: 10
Have you still got the router from your old ISP, any reason why you can't use that?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
