Using Thomson 582n as media server
- Re: Using Thomson 582n as media server
05-12-2011 12:17 PM
The content of the USB storage device cannot be profiled.
Content profiling is not possible because either the USB storage device:
Is not connected.
Has less than 250MB free space.
Is write-protected.
none of which are true, both with the uPnP media server option enabled and disabled.
It seems that there are a few possible causes for the failure to play:
1. I need to get the content profiling to work. Possible causes that occur to me are that my HDD, an old spare IOMEGA external 250G, is for some reason not compatible or that the firmware is not yet right?
2. The Sony SMP doesn't like uPnP and insists on DLNA.
Does anybody, who perhaps has access to a Thomson manual, have any advice about content profiling. and, more generally, about the compatibility of the uPnP and DLNA standards.
Otherwise it's off to get a NAS, which would be a pity as I get about 5M/sec writing to the 582n drive and people report less than half that to a GoFlex (for example) NAS.
05-12-2011 12:41 PM
( just google tg787 manual - the link is top of the list)
Extract from the manual
Quote 4.1.3 Using UPnP AV to Share Content with Media Devices
Introduction
If you want to share your media files with media devices like IP Set-Top Boxes, you have to configure the
Thomson UPnP AV Server.
The Thomson UPnP AV Server is a server that shares media files with devices that are connected to the same
network. These media files are stored on a USB storage device connected to the Thomson Gateway.
Procedure
Proceed as follows:
1 Enable UPnP AV on the Thomson Gateway.
2 Select your USB storage device as managed partition.
Proceed as follows:
1 Browse to the Thomson Gateway Web Interface.
2 On the Tools menu, click Content Sharing.
3 In the Navigation Bar, click Configure.
4 Under UPnP AV Media Server, click Server Enabled.
Proceed as follows:
1 Under List of connected disks, click the radio button next to the partition of which you want to share the
media files.
2 Click Apply
05-12-2011 1:01 PM
05-12-2011 1:12 PM
05-12-2011 1:18 PM
05-12-2011 1:57 PM
06-01-2012 3:27 PM
Thus: if you want to use the media server feature on the Thomson 582n, then you need to connect the drive to the USB port before booting up the router - an aspect of the set up not detailed in the 582n help pages.
06-02-2013 11:47 PM
What do you mean by a warm Kernel restart? I've just today been connected to my new PN fibre connection and am having the exact same problem as you described. I know it should work because coincidentally the router provided by my previous ISP was the same model and I had the DLNA media server function working just fine.
After reading your solution above I've tried rebooting my router with the USB HDD plugged in but it has made no difference. Any other ideas?
07-02-2013 7:59 AM
The FTTC version of the router requires a different 10.x firmware, but the same restriction applies, or so it has been posted here. My solution has been to add a gigabit switch and to plug my media servers into that. It is also a lot faster.
07-02-2013 1:13 PM
Many thanks.
