Usenet Speeds
- Re: Usenet Speeds
Usenet Speeds
28-10-2011 6:04 PM
Hi ive just got plusnet value fibre and im wondering what speeds i should get from usenet? I was downloading last nite and could only obtain 50kbs using astra server.
Message 1 of 8
(1,191 Views)
7 REPLIES 7
Re: Usenet Speeds
28-10-2011 6:11 PM
If you look <a href="http://usergroup.plus.net/prodcomp1.php">here</a> and put in value fibre you will see the rates during the day.
Message 2 of 8
(524 Views)
Re: Usenet Speeds
28-10-2011 6:46 PM
...and don't forget that those speeds are bits per second (kbps) whereas most news readers report the speed in bytes (kBps).
Message 3 of 8
(524 Views)
Re: Usenet Speeds
28-10-2011 6:50 PM
True, remember 5Mb/s is 0.5 MB/s (or as near as makes no difference anyway)
Message 4 of 8
(524 Views)
Re: Usenet Speeds
28-10-2011 7:40 PM
oops read your link wrong so i can download full speed between 1am and 7am then?
Message 5 of 8
(524 Views)
Re: Usenet Speeds
28-10-2011 7:49 PM
Not really - it just isn't rate limited
Go to http://www.plus.net/support/broadband/speed_guide/traffic_management.shtml and click on How is traffic prioritised? and you will see that Usenet is classified as Best Effort which basically means that if we have any bandwidth left over from the Gold, Silver and higher then it will get it
If you really want to use Usenet a lot you might be better off with the Pro Addon
Message 6 of 8
(524 Views)
Re: Usenet Speeds
28-10-2011 9:28 PM
Hmm that doesnt inspire much confidence at all ill see what kinda speeds i get tonight.
Message 7 of 8
(524 Views)
Re: Usenet Speeds
31-10-2011 10:45 AM
Hi ramborobert,
You could always get the Pro add on which would give you line speed at all times.
Jojo
Jojo
Message 8 of 8
(524 Views)
