Usenet Limited Speed Ater 6pm For Unlimited!
- Usenet Limited Speed Ater 6pm For Unlimited!
28-02-2013 7:05 PM
currently ongoing, my usenet speed has dropped from over 56 Mbps to 1 Mbps!
Outside of Usenet speeds are normal so it's not related to gateways or my connection. What is going on?
Re: Usenet Limited Speed Ater 6pm For Unlimited!
28-02-2013 9:10 PM
Is anything else affected?
Ex-Broadband Service Manager
28-02-2013 9:19 PM
Do you think the network problems are related? Can you provide any solutions?
28-02-2013 9:33 PM
01-03-2013 7:33 AM
During the day I have been downloading at line speed on Usenet (for me that's 57.5 Mbps). However last night my speed only on Usenet dropped to 1 Mbps. I tried various ports, all the same and tried swapping gateways, all the same. This morning 7am Usenet is back to line speed.
The night before, e.g. Wednesday evening everything was slow varying between 1 Mbps to 10 Mbps (e.g. not confined to Usenet)
I am on Fibre Unlimited so, all ports should be at line speed 24/7, as I understand it.
I believe this all relates to the current network issues, which are still be investigated. Hopefully this will sorted out soon.
01-03-2013 9:07 AM
Another user was having similar issues and his provider was at fault.
01-03-2013 9:20 AM
as it's the first time it happened last night and is, in my opinion related to to the current network issues.
01-03-2013 9:43 AM
01-03-2013 9:48 AM
01-03-2013 12:15 PM
01-03-2013 12:43 PM
01-03-2013 12:59 PM
Hope it doesn't happen again this evening, then!
01-03-2013 1:05 PM
01-03-2013 5:46 PM
You are currently connected to gateway pcl-ag08. This is located in City Lifeline House.
Download speed in the evening have been bad going down to 2.6Mb on Wednesday (results from SamKnows whitebox). Speeds start to drop between 4pm and 11pm. Before last reconnect speeds steady 24/7 at 51Mb since I joined in November,
Rebooted router this morning and now on gateway
You are currently connected to gateway pcl-ag05. This is located in City Lifeline House.
I'll check whitebox in morning to see what speeds are like tonight, but there is a problem somewhere on Plusnet network with curtain gateways as others are having problems. Big thing is if your IP drops at BT end then it does not always go backup even if line stable for days after a reboot. Plusnet have a problem that needs sorted as speed should be equal on any gateway as we are at present on a gateway lottery for speed.
01-03-2013 6:28 PM
http://community.plus.net/forum/index.php/topic,111170.0.html
