Usage report showing no usage
flinflon
I'm 9 days into latest month (Dec) and the usage report is showing nothing. However, my PC Networx  usage report shows over 1 GB usage so far current reporting period.  Is there a problem at PlusNet end?
Aspiring Hero
Fixes: 70
Re: Usage report showing no usage
There has been for heaven knows how long but as most customers are on unlimited contracts very few bother about it.
Fixes: 538
Hi there.
I'm sorry to hear you're having problems viewing your usage.
I'm experiencing the same issue for you, so I've refreshed things on your account now.
Could you switch your router off for 10 minutes then back on, letting us know if you can view your usage after that?
flinflon
As requested turned off for 10+ mins. Still no usage reported. Will try again over weekend.
flinflon
All OK thanks
