Usage limit worry
- Usage limit worry
Usage limit worry
09-10-2009 9:01 AM
If you get to your usage limit and reach your price limit what happens if you keep using the service does it just slow down?
Message 1 of 6
(1,350 Views)
5 REPLIES 5
Re: Usage limit worry
09-10-2009 10:05 AM
When you reach your limit your traffic will be stopped and if you try to visit a web page you'll be redirected to the data transfer watch page on the portal. This will give you the option to change the limit if you wish to pay for more bandwidth.
Hope that helps,
Hope that helps,
Message 2 of 6
(524 Views)
09-10-2009 10:29 AM
The option to buy more bandwidth is not available on all products though, is it?
Message 3 of 6
(524 Views)
09-10-2009 10:41 AM
It's available on Value, Pro, Broadband PAYG and Broadband Your Way.
Message 4 of 6
(524 Views)
09-10-2009 10:58 AM
James I'm confused because I have data watch which I had an email saying i'd gone over my limit but my connection still works and when I spoke to customer services last night they said the connection just slows downmy username is mpratley1986 could you have a look because I'm worried I'm going to get a bill now
thanks
thanks
Message 5 of 6
(524 Views)
09-10-2009 11:00 AM
That's a bit different.
If you go over your usage allowance, the speeds will just slow down. You can then elect to pay for additional usage or just live with the speeds.
However, there is also something called data transfer watch which essentially allows you to stop going over the amount that you pre-select. Your connection would then essentuially, stop, rather than just be slowed down.
Message 6 of 6
(524 Views)
