Upstream Speed
Hadders
Upstream Speed
Hi.  Is the upstream speed capped?  I am trying to backup photos onto the cloud and getting about 120kb/s which is going to take forever.  Downstream speed is fine.
6 REPLIES 6
Fixes: 63
Re: Upstream Speed
Morning @Hadders, thanks for your post.
I've checked the line and although I'm not detecting an actual fault, it does appear that the 'DLM' was set a little low on your U/L.
I've amended this for you now and you should notice it creeping up over the next hour or so.
For reference, it's not a setting that we've set - it's automatically set by the exchange. Also, as per Openreach estimates you're likely to only get a maximum of 1.5mbps U/L.
Please let us know if the changes I've made don't help, or if you need anything else at all.
 Owen P
Fixes: 94
Re: Upstream Speed
On ADSL , really :huh: I thought the absolute theoretical max on ADSL2 was 1.4mbps and anything above 1.2mbps is about as rare as the proverbial RHM
Fixes: 293
Re: Upstream Speed
@MisterW I suspect that he was looking at the AnnexM field on our systems which does offer up to 1.5mbps at the expense of some download speed
 Matthew Wheeler
Fixes: 94
Re: Upstream Speed
@MatthewWheeler As this is not in the Business forum I assumed it was residential.
Annex M isn't available on residential accounts is it ?
Fixes: 293
Re: Upstream Speed
@MisterW It's not hence the confusion above Smiley
Our internal estimate checkers still show it as available regardless of the type of account which is why I think it was mentioned above.
As you've said the highest upload sync speeds tend to be around 1.2mbps
 Matthew Wheeler
Hadders
Re: Upstream Speed
Hi @OskarPapa,
Thanks - that worked great.
All the best,
H
