Upstream Speed
FIXED- Subscribe to RSS Feed
- Upstream Speed
17-01-2019 8:41 PM
Hi. Is the upstream speed capped? I am trying to backup photos onto the cloud and getting about 120kb/s which is going to take forever. Downstream speed is fine.
Fixed! Go to the fix.
18-01-2019 8:53 AM
Morning @Hadders, thanks for your post.
I've checked the line and although I'm not detecting an actual fault, it does appear that the 'DLM' was set a little low on your U/L.
I've amended this for you now and you should notice it creeping up over the next hour or so.
For reference, it's not a setting that we've set - it's automatically set by the exchange. Also, as per Openreach estimates you're likely to only get a maximum of 1.5mbps U/L.
Please let us know if the changes I've made don't help, or if you need anything else at all.
Re: Upstream Speed
18-01-2019 9:07 AM - edited 18-01-2019 9:08 AM
On ADSL , really I thought the absolute theoretical max on ADSL2 was 1.4mbps and anything above 1.2mbps is about as rare as the proverbial RHM
Re: Upstream Speed
18-01-2019 11:32 AM
@MisterW I suspect that he was looking at the AnnexM field on our systems which does offer up to 1.5mbps at the expense of some download speed
Re: Upstream Speed
18-01-2019 1:31 PM - edited 18-01-2019 1:31 PM
@MatthewWheeler As this is not in the Business forum I assumed it was residential.
Annex M isn't available on residential accounts is it ?
Re: Upstream Speed
18-01-2019 2:39 PM
@MisterW It's not hence the confusion above
Our internal estimate checkers still show it as available regardless of the type of account which is why I think it was mentioned above.
As you've said the highest upload sync speeds tend to be around 1.2mbps
Re: Upstream Speed
18-01-2019 5:18 PM
