Uploading to Flickr
- Uploading to Flickr
- « Previous
- Next »
Re: Uploading to Flickr
08-05-2008 5:07 PM
Thanks!
08-05-2008 7:37 PM
08-05-2008 7:59 PM
09-05-2008 9:28 AM
If this is a temporary fix however, does this mean that the problem is going to resurface?!
09-05-2008 12:39 PM
Quote from: bande If this is a temporary fix however, does this mean that the problem is going to resurface?!
It shouldn't do, however if it does we should be in a much better position to tackle the position now we have an understanding of what happened this time round.
09-05-2008 12:43 PM
Quote from: Bob now we have an understanding of what happened this time round.
Which was?
09-05-2008 12:50 PM
The solution at the moment is temporary because Flickr traffic is completely bypassing our IWF solution. We will need to rectify this once we're confident this particular issue is fully resolved.
09-05-2008 1:35 PM
12-05-2008 8:19 PM
Chris
12-05-2008 8:30 PM
http://www.flickr.com/help/forum/en-us/72570/
16-05-2008 11:23 AM
Quote from: pierre_pierre managed to upload my first set and apply a map source, then found that the free is only 100 per month, is the pro upgrade worth the cost?
Yes!
16-05-2008 11:52 AM
- « Previous
- Next »
