Upload uncap request
- Upload uncap request
12-10-2011 10:42 PM
Hi, my upload is always around 377kbs. Could I request an unblock if there is no charge involved. Thanks.
Stephen
Stephen
Message 1 of 6
(1,132 Views)
5 REPLIES 5
Re: Upload uncap request
13-10-2011 11:27 AM
Quote Could I request an unblock if there is no charge involved.
Sure, we can do this with 24 hours notice usually. I just need to make sure you're aware that you may loose a small amount of the connection's downstream in order to accommodate this before I go ahead and raise an order.
Message 2 of 6
(564 Views)
13-10-2011 9:02 PM
Thanks. I will give it a try. Is it a situation whereby if I find it too slow on the downstream that I can request to have the cap turned back on?
Message 3 of 6
(564 Views)
14-10-2011 11:19 AM
We can re-cap the upstream if need be, sure. Likewise it's a 24 hour order.
Message 4 of 6
(564 Views)
14-10-2011 5:31 PM
Thanks. Can i please request an un-cap of the upload stream . Thanks
Stephen
Stephen
Message 5 of 6
(564 Views)
17-10-2011 10:22 AM
The order's been placed for you and should be completed tomorrow.
Message 6 of 6
(564 Views)
