Upload sync capped?
- Upload sync capped?
Re: Upload sync capped?
24-01-2015 2:47 PM
If, when you check with a corded phone there is still noise on the line then you need to raise a phone fault
24-01-2015 3:23 PM
how does my logic/process sound?
do you think i have found the fault?
do you still think its capped or banded?
if so how do i go about getting it removed?
thanks for you time oldjim
peter
24-01-2015 3:26 PM
do you think i have found the fault? Very likely
do you still think its capped or banded? Probably banded
if so how do i go about getting it removed? Let us see what happens over the next couple of days as staff probably won't pick it up here until Monday
A question
Were there any phones connected to the other sockets as it may be a dodgy filter
24-01-2015 3:31 PM
24-01-2015 4:14 PM
24-01-2015 4:45 PM
The upload speed is currently capped, so I've placed an order to uncap it which should complete by Tuesday morning. It sounds as though you've identified the cause of the noise on your line, but please feel free to update your fault ticket if you have any further findings to add.
24-01-2015 5:54 PM
26-01-2015 10:18 AM
26-01-2015 11:15 AM
26-01-2015 3:50 PM
26-01-2015 3:52 PM
27-01-2015 1:52 PM
27-01-2015 2:22 PM
27-01-2015 2:49 PM
28-01-2015 10:04 AM
Once we've got this sorted, we'll sort the upload out for you.
