Upload speed
- Re: Upload speed
Upload speed
13-05-2014 10:57 AM
Can I get an increase in my upload speed ?
Modem shows this
ADSL Link Downstream Upstream
Connection Speed 2887 kbps 445 kbps
Line Attenuation 56 db 17 db
Noise Margin 7 db 15 db
speed test results
Today 09:26 2132 kbps (267kB/s) 375 kbps (46.9kB/s)
Thanks Mike
Modem shows this
speed test results
Thanks Mike
Message 1 of 6
(983 Views)
5 REPLIES 5
Re: Upload speed
13-05-2014 11:05 AM
Hi mikesin,
I've just placed an order for your upload speeds to be uncapped. You should notice a change in the early hours tomorrow morning.
Message 2 of 6
(642 Views)
Re: Upload speed
14-05-2014 3:48 PM
Many thanks will try later
Message 3 of 6
(642 Views)
Re: Upload speed
15-05-2014 6:02 AM
Tried sped test today
Today 05:58 2159 kbps (270kB/s) 331 kbps (41.4kB/s) Share
Today 05:46 2281 kbps (285kB/s) 350 kbps (43.8kB/s) Share
Connection Speed 2963 kbps 656 kbps
Noise Margin 9 db 6 db
Connection upload speed gone up but throughput gone down ?
Message 4 of 6
(642 Views)
Re: Upload speed
15-05-2014 6:36 AM
Based on your previous posts, your netgear DG834GSP v3 may benefit from newer firmware, based on the firmware version of V1.01.03 it might take the same firmware as the standard DG834G v1 and v2.
Also it may benefit from being set to ADSL2 rather than auto which will end up connecting as ADSL2+. It may also benefit from various other tweaks or even a new power supply, but setting ADSL2 mode and all other tweaks have to be done via telnet. Anyway, any problem will initially be blamed on the netgear once Plusnet realise what it is.
Message 5 of 6
(642 Views)
Re: Upload speed
15-05-2014 8:01 AM
Thanks - will try ADSL - tried no effect
Rather than mess with firmware of modem I will try putting plusnet original Speedtouch modem back into play.
2100 Tried speedtouch and got 600K upload - replaced netgear and guess what ....got 600k upload. Obviously the un-capping took time to come into effect -glad i ddin't mess with Netgear firmware. Removed change to ADSL setting as it had no effect on upload speed
Thanks plusnet
Thanks plusnet
Message 6 of 6
(642 Views)
