Upload speed reduces with time
ruddleston
We have very slow broadband (usually 2-3mb/s download 0.5 - 1mb/s upload.
If I try and upload a large file using a file transfer web site the upload speed starts at around 0.8MB/s and gradually reduces to 50KB/s (virtually stopped) over a 5-10 minute period. I've tried different file transfer web sites and the same thing happens. I basically can't use PlusNet broadband for uploading.
3 REPLIES 3
VileReynard
Fixes: 20
Re: Upload speed reduces with time
50KBytes/sec = 500kbits/sec or 0.5Mbits/sec
The speed reduction may be the remote site trying to match the bandwidth to your upload speed.
Fixes: 419
@ruddleston
m=milli or thousandths
M=Mega or millions
b=bit
B=Byte or 8 bits.
You may wish to clarify.
Alternatively, if we assume that your upload is normally 0.5-1Mb/s, which is reasonable for an ADSL connection, not mb/s, then that equates to 62.5-125kB/s. If you include overheads then 50kB/s is not an unreasonable upload speed for this connection.
The initial surge will probably be a buffer emptying that you are seeing.
Maybe you are expecting too much from an ADSL connection and it's not Plusnet on this occasion who are at fault?
MatthewWheeler
Fixes: 479
Thanks for your post @ruddleston
From what I can see we've inadvertently capped your upload at 448Kbps instead of the uncapped one.
I've placed an order to change this and it should go through on Monday.
Let us know if you haven't seen an increase by then
 Matthew Wheeler
