Upload speed noise margin
- Re: Upload speed noise margin
10-10-2014 11:07 AM
My upload noise margin is stuck at 16
Type Interleave Path
Status SHOWTIME
Downstream Upstream
Data rate(Kbps) 22660 864
Noise Margin 6 16
Output power(dBm) 12 19
Attenuation(dB) 11 7
Any chance it could be bought back down to 6.
Thanks.
10-10-2014 11:43 AM
10-10-2014 5:25 PM
I've done some further checks on the line for you. We can ask that the SNR on the upstream is lowered, but can I ask what you are trying to achieve from this? You shouldn't see any difference to the upstream even with the lower SNR.
Thanks,
Tony
10-10-2014 5:50 PM
10-10-2014 7:03 PM
10-10-2014 7:40 PM
10-10-2014 7:55 PM
I've just rebooted the router, To make sure.
Downstream Upstream
Data rate(Kbps) 22440 864
Noise Margin 6 16
Attenuation(dB) 12 7
Still the same.
10-10-2014 10:09 PM
11-10-2014 10:27 AM
13-10-2014 12:38 PM
Status SHOWTIME
Downstream Upstream
Data rate(Kbps) 22630 864
Noise Margin 6 16
Output power(dBm) 0 19
13-10-2014 3:17 PM
I've raised a ticket on your account to monitor this because it isn't as straight forward as I first expected. An order was placed to remove interleaving for you which should have helped. I expected this to go through this morning, but it's now due for tomorrow.
Tony
14-10-2014 10:31 AM
All seem's to be ok now.
Status SHOWTIME
Downstream Upstream
Data rate(Kbps) 23701 1216
Noise Margin 4 6
Output power(dBm) 0 0
14-10-2014 1:19 PM
